May 19, 2012, 06:41:51 PM
Author Topic: What cable should I use for my RGB lights?  (Read 703 times)
Offline ɟɐsʇǝppʎ
  • Global Moderator
  • Dedicated Elf
  • Country: au
  • I have C.L.A.P
    • View Profile
    • a very eddy xmas web site
  • State: New South Wales AU
« on: August 25, 2011, 05:13:06 PM »
  This question has come up a few times on what is the best type of cable to use for low voltage RGB lighting is.
  I and many others have found that using 4 core security cable is a cheap and useful cable to use, It is double insulated, colour coded, comes in 4 core and 6 core versions and also comes in 2.2 amp and 4.4 amp rated cable and is sold in 100 metre rolls
  So you now ask where do I get this security cable from. Well there are several sources, I just went down to my local electrical supplier and bought my rolls but you can get it also online. I found the below links to be of great value for Australian residents and the price per roll is actually cheaper than my local supplier charges (plus shipping).
7/020 size cable
This cable size refers to the number of strands (7) and the size per strand (020). This cable is rated for approx 2.2 amps and come in 4 and 6 core.
4 Core 7/020 cable  $25.00
6 Core 7/020 cable  $42.00
14/020 size cable
This cable size refers to the number of strands (14) and the size per strand (020). This cable is rated for approx 4.4 amps and comes in 4 and 6 core
4 core 14/020 cable  $42.00
6 core 14/020 cable  $62.00
www.AVERYEDDYXMAS.com
Your just jealous because the voices only talk to me
Offline YAGOONA LIGHTS
  • Generous Elf
  • Full Time Elf
  • Country: au
    • View Profile
    • Yagoona lights
Re: What cable should I use for my RGB lights?
« Reply #1 on: November 29, 2011, 09:10:29 PM »
hi Eddy on your flood lights what connectors are you using on the end of them for quick easy plug and play each year??
come and see the lights and tune into 106.7FM
im proud to have the CLAP
Offline ɟɐsʇǝppʎ
  • Global Moderator
  • Dedicated Elf
  • Country: au
  • I have C.L.A.P
    • View Profile
« Reply #2 on: November 30, 2011, 03:17:51 AM »
  • Generous Elf
  • Full Time Elf
  • Country: au
    • View Profile
    • Yagoona lights
« Reply #3 on: December 01, 2011, 10:09:31 PM »
awsome Eddy thanks for that
Offline nintender
  • New Elf
  • Country: us
    • View Profile
    • BarkingLarry
« Reply #4 on: February 22, 2012, 03:00:19 PM »
14/20...does anyone have an AWG rating for us Yanks? I'm thinking AWG20, am I close?
Offline ɟɐsʇǝppʎ
  • Global Moderator
  • Dedicated Elf
  • Country: au
  • I have C.L.A.P
    • View Profile
« Reply #5 on: February 22, 2012, 03:03:23 PM »
yes we have a close equivalent that is in the ACL lighting for dummies manual and looking at that it is
AWG21
« Last Edit: February 22, 2012, 03:12:16 PM by ɟɐsʇǝppʎ »
Offline Donny M. Carter
  • New Elf
  • Country: us
    • Facebook.com/http://www.facebook.com/pages/CarterChristmasLightscom/180586372001178?sk=wall
    • View Profile
    • Carter Christmas Lights
  • State: Outside of AU/NZ
« Reply #6 on: February 22, 2012, 03:16:10 PM »
More great info Eddy! Thanks for all the hard work you put in!
Donny
instance
