Set the address to 100 with the rotary switches, connected 24VDC, hooked up the ENTTEC Pro and the RGB strip and switched on.
Worked first try.......oh so nice considering our first Lynx 16 took us months to bring to life.... changed the address powered down and up again and the new address also worked.
[ Guests cannot view attachments ]
Checked the sensitivity by incrementing each colour level from 0 through to about 50. You can see a clear difference in each step up to about 15 and then the incremental difference reduces but still a big difference when you hit with the full 255. Also setting a level of 1 the intensity is actually very low.
With the 24 outputs you can control 8 RGB strips and at 100 gm weight and small size (90 x 140 x 40 mm) this unit has a lot of possibilities. It's only really limited by it's IP rating (IP20). Still you could put into a small box easy enough, either with or without the supplied plastic frame.
Handles 24V 5050 RGB strips with 60 LED's per meter up to about 6m (max 1 Amp per colour) but will be less with 12V RGB strips. Most people buy 5m rolls so suggest you get the 24V version.
So looks like as good as the spec. Really for $76 you can't go wrong....
