May 19, 2012, 07:01:54 PM
Author Topic: Deals Direct 180 Count Net Lights  (Read 219 times)
Offline David_AVD
  • Community Project Designer
  • Dedicated Elf
  • Country: au
  • Technology Mad Man
    • Facebook.com/http://www.facebook.com/pages/Audio-Visual-Devices/297531996950791?sk=info
    • View Profile
    • Audio Visual Devices
  • State: Queensland AU
« on: November 20, 2011, 11:38:06 AM »
I just tried one of the Deals Direct 2 channel multicolour net lights on DC.  Running at 29V the net lights looks ok and results in a current draw of 400mA.
Each series string is 9 LEDs, so there are 20 of those strings in parallel (10 per channel).  This means each LED should be passing 20mA assuming all other things are equal.  Maybe 28V would be a safer bet to make sure the LEDs stay within their ratings.
It does look like you could split them into 4 channels with a bit of work.  This would involve breaking into the LED connections at the "top side" (same long side as power input) and running new wires.  Doable, but fiddly I'd say.
The overall construction looks a bit light weight, so I'm not sure if these net lights would last more than a couple of seasons.
Sure, everyone's always in favour of saving Hitler's brain, but put it in the body of a great white shark... oooooh, suddenly you've gone too far!
Offline David_AVD
  • Dedicated Elf
  • Country: au
    • View Profile
Re: Deals Direct 180 Count Net Lights
« Reply #1 on: December 08, 2011, 08:10:26 AM »
I've decided to use these net lights on the same 30V - 31V DC supply as the Big W strings.
For the white LED set, I added a 51 Ohm 0.6W resistor in series with each of the channel wires.  These values gave me approx 70mA current draw per channel from 31V DC.
For the multicolour LED set, I added three 15 Ohm 0.6W resistors (to get me 45 Ohms 1.8W) in series with each of the channel wires.  These values gave me approx 120mA current draw per channel from 31V DC.
instance
