May 19, 2012, 07:27:38 PM
Author Topic: Soldering Stations - what you have pros and cons  (Read 2313 times)
Offline AussiePhil
  • Administrator
  • Dedicated Elf
  • Country: au
    • View Profile
  • State: Australian Capital Territory AU
« on: April 30, 2010, 10:37:20 AM »
I have a GOOT RX-711-AS
The RX-711AS soldering station is a precision, Japanese manufactured instrument with excellent temperature stability and anti-static characteristics.
The light weight soldering pencil has a grounded tip and incorporates a ceramic heater with an integral temperature sensor. The sensor provides precise tip-temperature information to the heater controller which maintains the selected heat setting with a high degree of accuracy.  The silicone cord is incredibly supple.
The control panel includes the digital temperature display panel, a rotary temperature control, calibration control and a display changeover switch to display either the desired or actual tip temperature.  The panel is secured behind a darkened see-through cover which prevents accidental temperature changes but can be easily accessed when required.
* Safety approval number QASTE4930.
* 230-240VAC supply voltage
* 24VAC  output voltage
* 65 Watt capacity heater
* 200 - 480°C temperature range
* ±3°C temperature hysteresis
* 1.1Mtr iron cable
* 1.3Mtr mains cable
* 0.5mm tip supplied
http://www.goot.co.jp/e/item.html?c=58
Pro's
* 0.5mm tip perfect for fine work even with SOIC SMD.
* Can leave on all day and not worry about the tip
* Adjustable temperature
* Fast heat up
Con's
* That fine tip as supplied is useless for soldering big things like fuse clips etc on 3oz and 4oz boards, it will work on 2oz boards but struggles.
* The range of different tips is extremely hard to find to buy.
* Expensive compared to the typical ebay soldering station.
* A second Soldering Iron is required for heavy duty work.
Would I buy another one - Yes
Phil
Be Kind - Be Nice - Join In
It's your Forum
Offline ɟɐsʇǝppʎ
  • Global Moderator
  • Dedicated Elf
  • Country: au
  • I have C.L.A.P
    • View Profile
    • a very eddy xmas web site
  • State: New South Wales AU
Re: Soldering Stations - what you have pros and cons
« Reply #1 on: April 30, 2010, 12:37:16 PM »
Im looking at getting this soldering iron as my old soldering iron is a bit old and worn. Whats your thoughts on this unit
http://cgi.ebay.com.au/60W-Soldering-Iron-Station-Digital-Temperature-Control-/360257737610?cmd=ViewItem&pt=LH_DefaultDomain_15&hash=item53e108d38a
www.AVERYEDDYXMAS.com
Your just jealous because the voices only talk to me
Offline AussiePhil
  • Administrator
  • Dedicated Elf
  • Country: au
    • View Profile
« Reply #2 on: April 30, 2010, 12:50:43 PM »
Based on what I read it looks good, the 4 bonus tips with different shapes is good, if you buy one it would be good to write up your opinion.
The only thing is it doesn't mention ESD or if it is ESD safe. not really something to stop you buying one of course
Phil
It's your Forum
Offline Steve22537
  • Generous Elf
  • Full Time Elf
  • Country: au
    • View Profile
  • State: Western Australia AU
« Reply #3 on: December 27, 2010, 03:12:30 PM »
Fasteddy, Did you end up purchasing the soldering station and if so are you happy with it? As I'm also looking to replace my tired Weller Soldering Station with a http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=140492488310&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en
Regards
Steve
Starting early to avoid the rush..........
Offline ɟɐsʇǝppʎ
  • Global Moderator
  • Dedicated Elf
  • Country: au
  • I have C.L.A.P
    • View Profile
« Reply #4 on: January 31, 2011, 12:02:40 PM »
Regards
Steve
I must say i never bought this as my current soldering iron did the job (just). One of the things that im looking for now is a soldering station with a hot air gun for doing surface mounted soldering. The one im interested in and that Phil has and is happy with is the Aoyue 968 from the Australian distributor http://www.ludatronics.com.au/page75.html
Offline taybrynn
  • Apprentice Elf
  • Country: us
    • View Profile
    • RockinChristmas
« Reply #5 on: January 31, 2011, 04:34:42 PM »
I've been looking at these four, trying to decide between them:
In general many of Aoyue models look like Hakko clones, but seem to have good reviews.
Aoyue Digital Soldering Station 937+ (45w, cheaper tips, tips more widely avail., hakko 937 compatible)
http://sra-solder.com/product.php/6145/22/1a5b23c396fb91df6e5a6b7591028183
http://www.aoyue.com/en/ArticleShow.asp?ArticleID=373
(lots of great reviews on multiple sites, a hakko clone?)
Aoyue 2900
http://sra-solder.com/product.php/6363/22/133662239853a3b68d468873966eec39
http://www.aoyue.com/en/ArticleShow.asp?ArticleID=327
(I think this model might be discontinued/replaced, lots of great reviews on many sites, 70w, out of stock?)
(tips are expensive, tips include new heating element in them, tip selection limited?)
(auto-off, motion sensing tips, pencil like iron, very fast heat up)
Aoyue 3210
http://sra-solder.com/product.php/6808/22/fe362475b27ad04e1077c0081885439e  (this was $73 a day ago!)
http://www.aoyue.com/en/INT3210.html  (70w)
(tips are expensive, tips include new heating element in them, tip selection limited?, nicer control than 2900?)
mpja 302a
http://www.mpja.com/category/Solder_Equipment/Solder_Stations/SOLDER_STATION_DIGITAL_TEMPERATURE_CONTROL_15141_TL.asp
(currently out of stock, 40W, what RJ on diy board uses, lots of tips, tips are reasonable)
If anyone could comment on these, as it related to this thread, it would be appreciated.
« Last Edit: January 31, 2011, 04:39:08 PM by taybrynn »
LOR 2008-2010, 256ch, 2 homes., RGB wanna be, DMX newbie & DIY freshman, EDM LCD w/RDS., spiral mega in 2010?
Offline taybrynn
  • Apprentice Elf
  • Country: us
    • View Profile
    • RockinChristmas
« Reply #6 on: February 01, 2011, 01:30:14 PM »
Found a much better price on the 2900.
http://www.circuitspecialists.com/prod.itml/icOid/8396
Offline ɟɐsʇǝppʎ
  • Global Moderator
  • Dedicated Elf
  • Country: au
  • I have C.L.A.P
    • View Profile
« Reply #7 on: April 04, 2011, 11:04:25 AM »
Well guys I have finally spent the cash and have purchased a Aoyue Int2702A+, i should have the unit in about a week or so and then ill do a review. Looks like this should see me through most things for the next few years.
For you Aussie members ive purchased the unit through Ludatronics so it is a 240vac unit instead of 220vac that can be sourced directly from China. The prices are good compared to other places ive looked
here is the link to Ludatronics and the solder station that i have purchased
http://www.ludatronics.com.au/page77.html
Offline DanoNJ
  • Full Time Elf
  • Country: us
    • View Profile
« Reply #8 on: April 05, 2011, 06:27:48 AM »
That's one fancy station you got there, Eddie!  Have fun with it!
Offline tuppet
  • Apprentice Elf
  • Country: au
    • Facebook.com/http://www.facebook.com/#!/pages/Tuppets-Christmas-Lights/155238074522319
    • View Profile
    • Tuppet's Lights
  • State: Victoria AU
« Reply #9 on: April 06, 2011, 09:31:05 PM »
On the other end of the scale...
I have this: http://www.justtools.com.au/prod2084.htm   - weller butane soldering iron.
Pros:
- sitting on the roof and a wire breaks? that's ok, there's a soldering iron in your pocket ready to go, just light it up and go for it. No power cords, very fast heat up time.  **Just don't put it back in your pocket when you're done...**
- Sitting in the garden testing a board but find a broken join? - yeah, you get the idea. handy dandy solder.
- need to solder a wire inside a box? short tool, no wires, very easy to manouver.
- can be used as a great heat gun (red hot iron vent near the tip releases impressive amounts of hot air, which works wonderfully on heatshrink). No need to carry both tools.
- who doesn't want a portable blow torch?
Cons:
- doing a long stretch of soldering? don't forget to break it up with time to refill the iron with butane every few hours.
- butane is probably not good for you.
- temperature variation is a little tricky to control, there is a dial but I have no idea what it equates to - just turn it up/down until it seems to melt the solder/heat the component fast enough.
- doesn't come with a stand, does tend to accidentally get turned of if you push it into a standard holder too fast.
- has a burning hot red iron on the side... right about where your face would be if you wanted to lean over and look right in close at what you're working on.  This can get to be kind of uncomfortable, especially the hot air when it reaches your eyes...
- see that lid it comes with? well, you'd be forgiven for thinking that it would be a lid to put on the iron to protect the tip... but it's not. It doesn't fit unless you remove the tip.
- want a fine point tip? or a thicker tip? there isn't much of a range, and the default is pretty big. No SMD for this tip.
All in all it is pretty useful, especially for christmas lights once they are installed in awkward places, but I would probably go for this as a second tool once you already had a nice temperature controlled stable iron for bigger projects.
« Last Edit: April 06, 2011, 09:36:52 PM by tuppet »
2011 Show:
23,000 lights
420 channels DMX + 2016 pixels.
www.tuppetslights.weebly.com
Offline mrpackethead
  • Unsocialable Elf
  • Full Time Elf
  • Country: nz
    • View Profile
« Reply #10 on: April 08, 2011, 03:56:35 PM »
Hakko-FX951's are going to be my work horses.    Very impressed with it, and tip selection is awesome.     Lots of controlled power so you can jump between fine smd and large connectors with lots of copper without trouble..
http://www.hakko.com/english/products/hakko_fx951.html
Regards Andrew / 付强
www.stellascapes.com
skype: mrpackethead
Want to talk blinky?  blinkychat is here
Offline Steve22537
  • Generous Elf
  • Full Time Elf
  • Country: au
    • View Profile
« Reply #11 on: April 09, 2011, 02:32:53 PM »
Thats a mighty fine station, where would the best place to purchase one be.
Offline ѕυρєямαη
  • Global Moderator
  • Senior Elf
  • Country: au
  • I Have C.L.A.P and its very infectious
    • View Profile
    • www.manningsavxmas.com
  • State: Queensland AU
« Reply #12 on: November 27, 2011, 04:31:49 PM »
Can anyone see a problem with something like this for general hobby use. WIfe needs to get me a Chrissy present.
http://www.ebay.com.au/itm/2-1-Hot-Air-Digital-Soldering-Rework-Station-SMD-OZ-/260686424506?pt=AU_B_I_Electrical_Test_Equipment&hash=item3cb21f29ba
Steve
C-hristmas L-ighting A-ddiction P-roblem
Offline lithgowlights
  • Generous Elf
  • Full Time Elf
  • Country: au
    • View Profile
« Reply #13 on: February 24, 2012, 01:06:32 PM »
I just bought an Auyue 968 soldering station and so far am impressed. The soldering iron came with a fine tip and so far I have used it to build 3 LED Floodlights and have found it quick to heat, accurate temperature control (200-480C, 392-896F).
The unit has a smoke absorber, which is effectively a small tube which sucks air from about 1cm above the solder tip, then passes it through filters in the base. Using it today I could only smell a slight hint of solder flux while using it, which is a brilliant, and definately better for your health.
In addition to the iron, it has SMD hot air supply, probably not good enough to do large scale SMD, but for rework and small jobs I think it would be fine. It has excellent push button temperature control and monitoring, and an adjustable flow rate, as well as 5 additional shaped nozels to help direct air where you want rather than spilling out over a large area.
Power. This thing is fancy, but even with all the gear turned off, it still draws 14 watts in standby, which was a bit of a suprise.  The iron draws 28 watts when heating, and toggles on and off to keep the tip very close to the set point. The vacuum pump draws about 13 watts when running as a smoke remover. The hot air supply draws quit a bit of power, peaking over 600 watts when heating up, but averaging only 60 watts once it is at the set temperature, which was a suprise, and on turning off the hot air supply it blows air through the nozle until it cools to about 90c.
I tried the hot air system and it seems to work well, although I think I need help on airflows, temperatures etc to get the most out of it.
The item was sourced from Aliexpress for AU $182 delivered via courier in 3 days (Ordered Tuesday, arrived Friday)
Dave
2012 - Fireworks, pixicles and more pixels!
32 channels? More like 32 Universes ...
Offline YAGOONA LIGHTS
  • Generous Elf
  • Full Time Elf
  • Country: au
    • View Profile
    • Yagoona lights
« Reply #14 on: February 24, 2012, 08:58:55 PM »
well i have just bought a Auyue 937+
it is a basic soldering station but great for its price and love the temp control on it.
is is a review i found on it before purchasing
Aoyue 937+ (937 Plus) Solder Station Review
and this is the link to it on ebay
http://www.ebay.com.au/itm/140613113487?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
great product and fast delivery only took 4 days for me to get it.
come and see the lights and tune into 106.7FM
im proud to have the CLAP
instance
