May 19, 2012, 07:29:35 PM
Author Topic: 3 M, 30 LED, 3 AA battries  (Read 203 times)
Offline Slite
  • Generous Elf
  • Apprentice Elf
  • Country: se
    • Facebook.com/http://www.facebook.com/Slite62
    • View Profile
    • Blinky Blinky Lights
« on: January 30, 2012, 11:27:42 PM »
Seen these available at REALLY low prices.
Has anyone done any experimenting with these? Could one do something "useful" with them, i.e. making them longer or combining them in other ways?
Blinky Blinky Lights! I've got the C.L.A.P. (And not afraid to admit it)
http://www.blinkylights.se
Offline David_AVD
  • Community Project Designer
  • Dedicated Elf
  • Country: au
  • Technology Mad Man
    • Facebook.com/http://www.facebook.com/pages/Audio-Visual-Devices/297531996950791?sk=info
    • View Profile
    • Audio Visual Devices
  • State: Queensland AU
Re: 3 M, 30 LED, 3 AA battries
« Reply #1 on: January 30, 2012, 11:29:26 PM »
That's a bit cryptic for me - got a link or picture?   :)
Sure, everyone's always in favour of saving Hitler's brain, but put it in the body of a great white shark... oooooh, suddenly you've gone too far!
Offline Slite
  • Generous Elf
  • Apprentice Elf
  • Country: se
    • View Profile
Offline ѕυρєямαη
  • Global Moderator
  • Senior Elf
  • Country: au
  • I Have C.L.A.P and its very infectious
    • View Profile
    • www.manningsavxmas.com
« Reply #3 on: January 30, 2012, 11:48:10 PM »
well there defiantly DC and i'm sure a 5v power supply could be turned back to 4.5 volts
Steve
C-hristmas L-ighting A-ddiction P-roblem
Offline dropbear_luke
  • Apprentice Elf
  • Country: au
    • View Profile
« Reply #4 on: January 31, 2012, 04:07:02 AM »
Id be really interested in what people come up with for these too. I have numerous ones at home, approx 2 metres long each, with 20 LED's poweres by 2 x AA Batteries.  Was thinking of obtaining a controller of some sort and joining multiple strings to make some sort of flashy blinky thing.  Not too sure what yet. still trying source an appropriate controller.
Offline David_AVD
  • Dedicated Elf
  • Country: au
    • View Profile
« Reply #5 on: January 31, 2012, 08:06:40 AM »
The trouble with these strings is that the LEDs are all in parallel.  Sometimes they have a current limiting resistor(s), sometimes not.
I've seen one where the batteries fed the string via a single resistor.  Others (particularly the solar versions with one battery) have a little PCB that steps the voltage up a little and also provides the current limiting.
In short, you can run these from a higher voltage, but the parallel wiring means the series resistor value needs to be chosen very carefully.  Also, if the PSU voltage is too high, you waste a heck of a lot of power in the series resistor.
That said, the candy canes on my mesh display element employ parallel LEDs and I run them from a 5V controller with suitable series resistors.
Offline ԆцряєсϮ
  • Generous Elf
  • Apprentice Elf
  • Country: au
    • View Profile
  • State: Victoria AU
« Reply #6 on: January 31, 2012, 10:03:18 AM »
I have some 120 led solar lights that I've been playing with (3 ch of 40 leds each), these are all in parallel as well running off 2 batteries (3.2V).
I ran them up to 4V where they are drawing 800mA with out the need for any current limiting resistor.
I was thinking of running them off one of Rays 5V supplies as these can be wound up or down a bit. Also they will be going right at the front of my display which is the longest cable runs so I may have some voltage drop to help out as well.
Just waiting on some supplies from Ray to continue my testing.
Rod
Rod
Disclaimer
Please be advised that nothing found here has necessarily been reviewed by people with the expertise required to provide you with complete, accurate or reliable information. That is not to say that you will not find valuable and accurate information in this post, Much of the time you will. However, We cannot guarantee the validity of the information found here. Any resemblance to real persons, living or dead is purely coincidental. No anchovies unless  otherwise specified. Apply only to affected area. Beware of Dog. Thank you come again!!
