All
As we are now much closer to a final release of this controller I thought it was time to open up an interest thread to gauge how many might be needed.
For details on this controller see
http://forums.auschristmaslighting.com/index.php/topic,231.0.htmlPricing will be as follows and is provisional on final assembly cost, whilst it is a little higher than indicated in Chat the other day it is hoped still that it may even come down. (all in US Dollars)
Bulk Buy price based on 50 units being ordered
All units will be assembled and fully QA tested to power up, process DMX and Output from both buffered outputs.
No cases supplied with options below as there are many ways for these to be enclosed.
Option1.
TP3212 as a fully assembled ModuleThis will be QA tested and supplied without cables, this enables you to wire it as per your own requirements.
Provisional Cost: US$36.00
Option2.
TP3212 as a fully assembled Module with full cable setThis will be QA tested and supplied with cables for all inputs and outputs, all cables supplied as male/female pairs so you can wire the connecting equipment as well.
Provisional Cost US$42.00
All cable connectors are o-ring sealed and should provide a nice weatherproof fitting.
Regards
Phil
