Hi,
After a lot of emails, research of frame building, i decided to share my creations around this component WS2801.
The idea is to build some different PCBs where we can use them on 12v/24v/48v.... Modifiable in fact.
Below some shoots of actual status :
2 different boards :
One rectangular, with SMD 5050 RGB 3 channels managed by 2801.
Second one round : regular or SMD leds, 4 channels with possibility to have static + dimmeable at same time.
Multi voltage to be adapted to each need.
My actual breadboard :
My actual controller from RAY for the WS2801: a catastrophic item as only 1 sequencing RGB and no possibility to use the DMX option; i asked Ray to get the software to edit the SD card and how to activate the DMX option, but no answer.
I found also the site from the manufacturer : ONUMEN, but no download available. So i made a request too...
The controller:
The idea is as the prototypes will be ready to launch a production if some of you were interested to get some original boards and populated them as your imagination. WS2801 will be an option too on the boards. But as i don't want to make business, it will be only for the PCBs..
For the moment i will appreciate to get as possible a real controller to advance on my project. I know some projects are running on this way, but i need one sample to play with the pixels and WS2801... If some one can helps....
The pixels from RAY... The PCBs are glued and no way to identify the chip and components inside...
More ASAP... Cheers Henri
