May 19, 2012, 07:49:12 PM
Author Topic: My TP3244 case solution  (Read 711 times)
Offline AussiePhil
  • Administrator
  • Dedicated Elf
  • Country: au
    • View Profile
  • State: Australian Capital Territory AU
« on: October 23, 2010, 09:54:20 PM »
Thought some people might like to see how i'm going to enclose my TP3244's
[ Guests cannot view attachments ]
A TP3244 all cabled up with a full compliment of 4 output cables and the incoming DMX signal on the right.
The power is not connected on this one and my personal plan is to hard wire the 5V back to a 5V power supply.
The 5pin header at the top is for a PIC Programmer.
The 4 x 2Pin headers at the bottom are the hard jumpers for setting limited output default options
The DMX terminate jumper is at the top right.
A full length picture showing the 4 x female tails for the pixel connections
Now we get to my trusty bits of PVC, specifically a short piece of 40mm pipe and a 40mm end cap.
As you can see in the next photo I have screwed an eye-hook into the inside of the endcap and just used a zip tie to hang the pcb from the hook.
As you can see, the Tiger TP3244 slips neatly inside the PVC pipe.
more...................................
Be Kind - Be Nice - Join In
It's your Forum
Offline AussiePhil
  • Administrator
  • Dedicated Elf
  • Country: au
    • View Profile
Re: My TP3244 case solution
« Reply #1 on: October 23, 2010, 09:54:31 PM »
......................more
The trick is to get the length just right so the connectors are out of the bottom of the pipe, allowing you to connect and disconnect as required.
Now with a simple eye-bolt screwed into the end-cap on the outside you can simply hang this from your pixel string or anything and have a nice rainproof enclosure
Phil
« Last Edit: October 23, 2010, 09:58:24 PM by AussiePhil »
It's your Forum
Offline ɟɐsʇǝppʎ
  • Global Moderator
  • Dedicated Elf
  • Country: au
  • I have C.L.A.P
    • View Profile
    • a very eddy xmas web site
  • State: New South Wales AU
« Reply #2 on: October 23, 2010, 10:03:37 PM »
Perfect simple cheap solution, Thanks Phil
www.AVERYEDDYXMAS.com
Your just jealous because the voices only talk to me
Online kel
  • Full Time Elf
  • Country: au
    • View Profile
    • Christmas Lodge
  • State: Queensland AU
« Reply #3 on: October 24, 2010, 06:19:32 AM »
Now, that is something I know I can handle  ;D
Offline mrpackethead
  • Unsocialable Elf
  • Full Time Elf
  • Country: nz
    • View Profile
« Reply #4 on: October 24, 2010, 06:39:43 AM »
wheres your power supply going
Regards Andrew / 付强
www.stellascapes.com
skype: mrpackethead
Want to talk blinky?  blinkychat is here
Offline smartalec
  • Full Time Elf
  • Country: au
  • SmartAlec's Productions
    • Facebook.com/http://www.facebook.com/SmartalecChristmasLights
    • View Profile
    • Smartalec's Lights
  • State: South Australia AU
« Reply #5 on: October 24, 2010, 09:27:21 PM »
Phil your not a plumber by any chance,
I guess your prototyping the idea..hehe
great work
Offline KeithTarpley
  • New Elf
  • Country: 00
    • View Profile
  • State: Outside of AU/NZ
« Reply #6 on: October 25, 2010, 12:51:56 AM »
Greetings,,,
So, everybody just needs to build Christmas Squids...
Keith
Now I know, the only foe is time - Moody Blues
Offline Mike
  • Full Time Elf
  • Country: au
  • CLAP infected!
    • Facebook.com/http://www.facebook.com/DelaneyParkwayChristmasLights
    • View Profile
    • LEDtopia
  • State: Western Australia AU
« Reply #7 on: October 25, 2010, 12:53:12 AM »
LoL @ squids
Offline fathead45
  • Full Time Elf
  • Country: us
  • Fiedler Xmas
    • View Profile
« Reply #8 on: October 25, 2010, 02:17:35 AM »
looks nice, would need a lil refined for people with snow haha.
Offline AussiePhil
  • Administrator
  • Dedicated Elf
  • Country: au
    • View Profile
Re: My TP3244 case solution - Squid Tubes
« Reply #9 on: October 25, 2010, 10:07:17 AM »
Squid tubes it is...
for people with snow, a bit of 1" thick foam to protect the open end and if you expect them to get buried then a bit of expanding foam sprayed in the end.
so build your Squid Tube today.
Phil
It's your Forum
Offline chrisl1976
  • Apprentice Elf
  • Country: 00
    • View Profile
« Reply #10 on: December 03, 2010, 09:25:23 AM »
Got my TP's finally yesterday and were very pleased to see that they fit perfectly in the small cases I got from Your Broadband store.  They are still available from them if you call, but there is now a 20 order minimum.  I think they were around $3.50 each
Chris
Creator of Lights on Sixth
www.LightsonSixth.com
