I'm wondering if anyone else with 6803 pixels with the 3.1 update have their TP3244 working properly. When I did all my build and testing in the shop, the TP3244 with the prior firmware/setup was working as expected. I am now unable to get it to work. I've tried:
* Output from LSP using the ECG (works on other universes, including an element that has the old TP3244 firmware)
* Output from a Lynx dongle using the startpattern program (confirmed working with other elements in the display)
* Made sure to do the power down, JP1, config, power up after the firmware flash (done twice now)
* Tried hooking up only one output
* Tried supplying power all from the same power strip (ground loop issues?)
* Tried switching the strips around (I have 8, 42 pixel strips all setup the same) on two different TP3244's
* Tried every combo I could resonably think of in the TP3244 software (setting all to None, just one output, different universe, etc, etc)
* Taken a laptop with Lynx dongle outside for testing to remove any cable length issues
I'm at a loss now. The reason I'm leaning toward firmware issue is that it was working on the old firmware and my other element that has the old config and firmware works fine still, with the same ECG/LSP setup. I updated the firmware to resolve the 3+ output issue.
Anyone have any other ideas for me to try?
