Lenny
First post here on ACL so hopefully I've read the rules correctly.
I have 16 sets of the BigW lights that a lot of you are familiar with and I have read that some have removed the factory controller all together or have altered it internally so that it is set to steady light at all times.
My question is what is the procedure to change the setting so that it only appears on another feature such as steady flash? is this even possible?
The reason i ask this is because i would like to set up my own style of sequence i guess you could call it. my budget simply doesn't allow for all the fancy gear that i wish i could have so I'm planning on simply using an ordinary power board with individual switches for each plug and just switching on each string of lights at a calculated interval in order to create the desired effect?
I do hope that explanation helps you understand what I am trying to do
