May 19, 2012, 08:01:53 PM
Author Topic: I can't read the print on the chip - what PIC does the TP3244 use?  (Read 331 times)
Offline JonB256
  • Apprentice Elf
  • Country: us
    • View Profile
Actually to the point of playing with the two I bought and want to update the firmware.
What PIC family do I set it for? Does it need power applied? (which may be why it doesn't auto detect?)
I'm not a very experienced PICkit user (yet).
JonB
Offline Tabor
  • Global Moderator
  • Full Time Elf
  • Country: au
    • View Profile
    • XMAS in Perth
  • State: Western Australia AU
Re: I can't read the print on the chip - what PIC does the TP3244 use?
« Reply #1 on: February 02, 2011, 12:31:59 AM »
Hello Jon
It uses a PIC32MX340F128H.
The board should be powered from an external source and make sure the pic is not supplying power to the board.
Offline dmoore
  • BetaTester
  • Senior Elf
  • Country: us
  • http://www.vimeo.com/18220911
    • View Profile
  • State: Outside of AU/NZ
« Reply #2 on: February 02, 2011, 12:54:11 AM »
Here is a video that shows the process for flashing the firmware.  This video is for the ECG8 but if you replace the chip type and firmware file you should be fine.
http://www.screencast.com/t/nX5TuRij7
« Last Edit: February 02, 2011, 01:30:23 AM by dmoore »
instance
