Let me preface this post by saying I am in no way an expert on this subject. However, I wanted to post some instructions in ‘lay mans’ terms for novices like myself.
I want to thank some of those that have helped me so far: Brain (budude) for some of the pictures you will see, Chuck (Cenote), DaveA, mrpackethead and others…..
There are several accepted methods of soldering SMDs (surface mount devices). One is by hand; another is using a hot plate and third is using a reflow oven. If you are reading this I guarantee you do not have a semi professional reflow oven, but I bet you have an old toaster oven. Same thing without the exacting control of temp. Well not really the same, but will do. Find below some links to the different methods.
Let’s get started. While some of the packets ordered will have different components, basically they are similar.
My strobes will be built with a PIC chip and use ½ w LEDs. They will not be triggered and remain on all evening (no controller input). Your application may vary.
Let assume you have all the components and boards. You will have a PCB – printed circuit board – which actually contains 40 individual boards. These will be separated due to the large board having been perforated. A little pressure and snap!
[ Guests cannot view attachments ]
I have preferred to construct mine in strips of 9 boards.
Currently I am hand soldering using wire solder (.022) and using only a simple soldering iron. Yes, I’m using less than perfect tools. I also have solder paste, however, not a hot enough hot plate. Solder paste can be used with a hand solder also. One thing I have found while speaking to different people is that everyone has an opinion on the best thing to use. You will find what works best for you. And along the way, you will learn several different methods, making this a great teaching project!
You will have to install four resistors, two chips (a NUD and a PIC), and a transistor and of course the LED. Please remember that the end result of your strobe may alter some of these steps.
Each side of the board will have components. We first identify the top. This is the side with writing (silk screening). Most all components will be housed here and a good place to start. The order in which you install the parts does not matter, so long as you install all of them. See what works for you.
I stated with the NUD. This is an 8 leg chip. The chip has an orientation and must be installed correctly. If you look at the chip, you will see a line (on mine) or dot. The dot denotes the number one pin. This line / dot is installed closest to the edge of the board. Using paste or wire solder, connect to the board. Be sure ALL legs are making contact. I used a photographer’s loop which I found helpful.
Instructions originally posted list a 6R98 resistor, however, the ones sent and work fine are 7R15. These will have a blue / green color to the top.
Next was the 7.5 ohm resistor – installed next to the NUD, followed by the 10K and 1K. In the photo you see the 1001 = 1K and 1003 = 100K. Please note the location of these.
Next I flipped the board over and installed the PIC which is the 6 legged chip. Install the same as the NUD. Follow this by installing the second 1K resistor (1001). Now back to the top, install the thru hole transistor – follow the silk screen on the PCB for orientation.
Finally the LED. I tested each LED prior to attaching. Any 3vdc power source will work and not harm the LED. The positive lead which is the longer of the two goes to the hole marked one.
We are pretty much done with the bulk of the construction now.
Following is a link to hot plate / paste method thanks to Joel (jrock64)
Here is a link to general instructions for SMD soldering:
http://store.curiousinventor.com/guides/Surface_Mount_Soldering/101Here is the link to some general discussion of the build of these on DYIC
http://doityourselfchristmas.com/forums/showthread.php?12881-Building-LED-StrobesNext we go to wiring these up! (you’ll have to wait, I’m not there yet…)
If I've made a mistake, please let me know!
Please see post below for a picture of a completed strobe. Note the way the LED is bent.
