A cordless screwdriver was the best thing i purchased last season, made life connecting up the hundreds of cables to the controllers so much easier.
Every channel equals TWO screws to turn.
The one i bought was a Ryobi Lithium screwdriver
http://www.ryobi.com.au/Products/Lithium-Ion/4-Volt/4V-LITHIUM-SCREW-DRIVER---in-GREEN.aspxInterestingly i could do the connectors by hand with a large jewellers screwdriver just a little faster but at the expense of a sore hand.
A size 3-4 slot bit will fit most of the multiway connectors used snugly.
If you have a lot of channels that connect to screw terminals then i would highly recommend you invest in a cordless srewdriver.
Of course you can use it for other things during the rest of the year
Phil
