May 19, 2012, 08:16:55 PM
Author Topic: PIXAD8 Testing and Production Notes ...  (Read 1863 times)
Offline j1sys
  • Community Project Designer
  • Full Time Elf
  • Country: us
  • There are no rules, and those are the rules.
    • View Profile
    • Joshua 1 Systems Inc.
  • State: Outside of AU/NZ
« on: April 26, 2011, 07:53:10 AM »
Well, I may have been quiet the last few weeks. I was VERY busy.
PIXAD8 PCBs arrived April 18th. Quickly assembled one and proceeded on testing. Worked on hardware and software all week and finally on Saturday afternoon got rolling test patterns working on a sting of WS2801 lights.
Now working on LPD6803 and then proceeding on to TM190X. Still a lot of software work to do, but that's what I do best. Have to finish E1.31 code, add ARTNET II code, add configuration screens etc.
But the hardware is fully tested at the logic level.
Today I received a 50 amp 12VDC power supply. I used MR16 50 watt mini-spots to test full loading on one of the power busses. Nothing melted (the wires to the lights got real hot but halogens will do that) but the +V and Ground traces got a little warmer than I would like under FULL load (28 amps). The whole room was getting hot with 350 watts of halogens trying to set my work table on fire. A note on the power supply: at first I had trouble with onrush current. I can't connect more than 12 amps of lights and turn power on and off at the power strip. For testing I had to use the individual string fuses as a switch and add a string (2x 4 amps) at a time. This is a problem with my supply and the use of halogens for testing.
Bottom line:
1) The logic is solid.
2) The software is functional but needs a lot of refinement to be ready for prime time but I have no worries on that issue.
3) Three mounting holes between the connectors across the front of the board do not have enough clearance around them for the screw head. Easy PCB design fix. Adds .5in to board length.
4) +V and Ground traces will be beefed up. Add 50% to +V and 100% to Ground. It was half sized but double layered. The power/heat didn't dissipate well enough. Adds .75in to board depth.
5) While redesigning I will switch from the standard blade fuse to the mini-blade fuse. The docs and listing for fuses and fuse holders from Keystone were confusing and I finally found the holder style I wanted in the mini-blade size.
So a good week of work with a lot of progress. I will refine the PCB design tomorrow and submit it soon. I will order a small first run of 55 boards, have 5 boards hand assembled, do a quick test and then, hopefully, release the others for production. If the 5 boards have problems I will junk the 50 PCBs and make any final tweaks necessary.
Attached are some photos of one board with just fuse holders and connectors being used for load testing and some photos of another board fully assembled with an ECG-M32MX sitting on top hooked up for software testing and development.
I also have the ability to remotely download firmware updates just about tested and will probably release this combination as the first boards that won't require a PICKit for updates. It still might be a good idea to have one available somewhere to borrow in case of an emergency since this is a new technique for me and could have some little quirks at first.
Everybody asks price. Still have to figure all costs but probably looking at $120 per set. People have asked about an enclosure. I looked into having an enclosure with pigtails or connectors and all of them added a lot of cost or reduced the amperage per string for a reasonable cost solution. I am going to acquire a quantity of CG-1000 and CG-500 enclosures (if it fits into the CG-500). I think a weatherproof enclosure with your cables coming into the box (any size or type) is more flexible. Of course you can make your own enclosure. I expect the CG-1000 to come in at about $15 including a mounting plate that adapts our hole pattern to the CG-1000 layout.
-Ed
oops - photos were too big. I will add a reply in a few minutes with links to the photos on our site.
Offline cenote
  • Full Time Elf
  • Country: us
  • Suburbs of Philadelphia
    • View Profile
« Reply #1 on: April 26, 2011, 08:00:03 AM »
Two thumbs up, sound promising. Thanks for the update.
Offline j1sys
  • Full Time Elf
  • Country: us
    • View Profile
Offline dmoore
  • BetaTester
  • Senior Elf
  • Country: us
  • http://www.vimeo.com/18220911
    • View Profile
Re: PIXAD8 Testing and Production Notes ...
« Reply #3 on: April 26, 2011, 11:41:23 AM »
Hot diggity dog - screw terminals!
This pricing includes the ECG-M24H "motherboard"?
Lookin' good!
Offline smartalec
  • Full Time Elf
  • Country: au
  • SmartAlec's Productions
    • Facebook.com/http://www.facebook.com/SmartalecChristmasLights
    • View Profile
    • Smartalec's Lights
  • State: South Australia AU
« Reply #4 on: April 26, 2011, 02:59:44 PM »
I reckon i have the perfect case for it allready at that size, has see through lid an all.
Looking Sweet as
Just let me know when its time to send you money.
« Last Edit: April 27, 2011, 02:41:21 AM by smartalec »
Offline chris_backus
  • New Elf
    • View Profile
« Reply #5 on: April 27, 2011, 02:45:23 AM »
+1 for interested!!
I probably would need two.
Offline David_AVD
  • Dedicated Elf
  • Country: au
  • Technology Mad Man
    • Facebook.com/http://www.facebook.com/pages/Audio-Visual-Devices/297531996950791?sk=info
    • View Profile
    • Audio Visual Devices
  • State: Queensland AU
« Reply #6 on: April 27, 2011, 07:03:50 AM »
Looks like the price includes the ECG-M32MX processor board and the new pixel drive board.
Sure, everyone's always in favour of saving Hitler's brain, but put it in the body of a great white shark... oooooh, suddenly you've gone too far!
Offline j1sys
  • Full Time Elf
  • Country: us
    • View Profile
« Reply #7 on: April 27, 2011, 10:14:40 AM »
Yes. That's what I meant by 'set'. I get tired of typing ECG-M32MX/ECG-PIXAD8 combo.
Sorry for any confusion.
-Ed
Offline christmas-light
  • Apprentice Elf
  • Country: dk
    • View Profile
    • Pcjulelys
« Reply #8 on: May 02, 2011, 03:37:44 AM »
Hi
Great Controller ;D
Is there anyone who have the mouser part nr for the connectors ? :)
Offline j1sys
  • Full Time Elf
  • Country: us
    • View Profile
« Reply #9 on: May 02, 2011, 05:32:52 AM »
they come with all connectors and i'll have spares available. may include 2 extra plugs with each (in case you lose them). i buy them in bulk from china. they are 3.5mm pitch pluggable terminal strips. the big ones are 7.62mm (.3in) pitch fixed terminal strips. the pluggable ones were VERY tall and a little expensive.
the fuses in the pictures on the prototype are standard blade. we are switching to mini-blades. both are standard parts at auto stores and walmart type stores.
-ed
Offline Eric outback NT
  • Generous Elf
  • New Elf
  • Country: au
  • Living the fast life
    • View Profile
  • State: Northern Territory AU
« Reply #10 on: May 02, 2011, 11:07:55 AM »
What is the ECG-M32MX and why is it in a combo with ECG-PIXAD8 ?
If everything seems to be going OK you have obviously over looked some-thing
Offline neil
  • Generous Elf
  • Full Time Elf
  • Country: us
    • View Profile
« Reply #11 on: May 02, 2011, 11:15:06 AM »
The ECG-MX8 is a common ethernet E1.31 controller that is a daughter board to the other output controllers like the PIXAD8 and DR8.
When J1sys sells the PIXAD8 controller you will get the ECG-MX8 daughter board that sits on top of the output board.
Currently we have seen the DR8 which supports 8 DMX or Renard outputs, and now the PIXAD8 which support 8 SPI Pixel outputs with power.
The DR4 is a self contained version of the DR8 but for 4 outputs of DMX/Renard and the MX8 is on the same board.
Neil in So Cal
Skype: neilric
MSN: neilric99@hotmail.com
Facebook: neilric99@hotmail.com
Offline jstjohnz
  • Apprentice Elf
  • Country: us
    • View Profile
    • SanDeviceS
« Reply #12 on: May 02, 2011, 11:57:49 AM »
-ed
Would you mind sharing the vendor/part numbers and pinout of your string connectors?  If I re-do my PCB, I'd like to go to pluggable screw connectors for the strings, and it seems like it would make sense to standardize.
the E680 Pixel Controller
      RGB Pixel Project
Offline stjohnson90
  • New Elf
    • View Profile
« Reply #13 on: May 02, 2011, 05:16:00 PM »
Count me in for purchasing a PIXAD8.
Any word on when it will be available?
  • Apprentice Elf
  • Country: dk
    • View Profile
    • Pcjulelys
« Reply #14 on: May 03, 2011, 08:51:12 AM »
-ed
Yes that would be cool  ;)
instance
