talk2coxie
Hi Guys, I promised a how to type post with the corro presents I made.
Pretty straight forward really and they say a picture says a thousand words. Feel free to ask any questions if I may have missed something you would like to know.
The black "ribbon" is just black corro cut up and hot glued around the outside.
As for the insides, I made another smaller corro box to leave all modules 50mm from the outside faces to allow good diffusion and even colour spread.
The corro present in the display are on vimeo. I have previously posted here if you want another look at the in action?
http://auschristmaslighting.com/forums/index.php/topic,5232.msg44926.html#msg44926
12 Volt RGB dumb modules used
http://www.aliexpress.com/item/promotion-5050-SMD-RGB-LED-module-DC12V-input-waterproof-20pcs-a-string/423204013.html
LARGE PRESENTS (200mm x 200mm x 200mm high)
https://dl.dropboxusercontent.com/u/43251051/IMAG0113%20-%20BIG%20PRESENT.jpg
https://dl.dropboxusercontent.com/u/43251051/IMAG0114%20-%20BIG%20PRESENT.jpg
https://dl.dropboxusercontent.com/u/43251051/IMAG0115%20-%20BIG%20PRESENT.jpg
MEDIUM SIZE PRESENTS (200mm x 200mm x 100mm high)
https://dl.dropboxusercontent.com/u/43251051/IMAG0116%20-%20MEDIUM%20PRESENT.jpg
https://dl.dropboxusercontent.com/u/43251051/IMAG0117%20-%20MEDIUM%20PRESENT.jpg
https://dl.dropboxusercontent.com/u/43251051/IMAG0118%20-%20MEDIUM%20PRESENT.jpg
https://dl.dropboxusercontent.com/u/43251051/IMAG0119%20-%20MEDIUM%20PRESENT.jpg
SMALL SIZE PRESENTS (200mm x 200mm x 50mm high)
https://dl.dropboxusercontent.com/u/43251051/IMAG0120%20-%20SMALL%20PRESENT.jpg
https://dl.dropboxusercontent.com/u/43251051/IMAG0121%20%20-%20SMALL%20PRESENT.jpg
https://dl.dropboxusercontent.com/u/43251051/IMAG0122%20-%20SMALL%20PRESENT.jpg
https://dl.dropboxusercontent.com/u/43251051/IMAG0123%20-%20SMALL%20PRESENT.jpg
https://dl.dropboxusercontent.com/u/43251051/IMAG0124%20-%20SMALL%20PRESENT.jpg
I hope this is of some help to you
