nutz4lights
Hey all,
So, these Technicolor RGB pixels arrived too late last year to get them up on the roof... I wanted the Technicolor pixels because of the screw-on C9 bulb cover (I am old-fashioned!). Little did I know of all the problems that the Technicolor bulbs would end up with, but that is a story for another post... So I decided that with our two-story house, and the length of ridges, gutter, etc, that I no longer wanted to get up on the roof like I used to and shingle and gutter clip the lights one by one. I had seen numerous posts from others around here and other forums that were in the same boat. I used some of their ideas and tried to come up with some of my own. I have four different kinds of mounting requirements:
Next it was a matter of figuring out how to attach the lengths of PVC pipe to the various elements. The gutters were easy. I used the vinyl J-hook that folks had already used. I cut sections of J-hook that were around 30cm in length and tried to space them every meter or so... worked wonderfully. For the front gables, I decided to use the square zip-tie base block things with a stainless steel screw going into the metal flashing/fascia on the house. That also had been done before and worked great. For the flat and inclined ridges, I decided to make legs based on snap-on PVC tees, which I'm sure someone has done, but I hadn't seen any pictures. For the inclined roof, I also had to attach the end of the string to something... and the back roof vent on the house seemed like the best thing... So I screwed a tiny eyehook into the edge of the metal and ran a steel cable to the end of the PVC pole.
Ok, pictures... First, there are a ton of pictures at the following link: http://www.seek-up.net/2014 - Christmas Display/
Here are some select pictures:
-Louie in Melbourne (Florida!)
- gutters
- flat ridges
- inclined ridges
- front gables
