Trying to get an NDB up
arw01
Eastern Washington
Got an NDB controller in today, my first one. From Eddy's manual, I see it's supposed to be 10.0.0.100, but I get nothing.
Changed the IP on the PC to 10.0.0.5 per the manual, still nothing. All my other network I am on 192.168.1.#.
I tried the reset, still no difference.
I have activity on the internet jack, but no green light (only amber) flashing but I am on a gigbit network.
Thoughts? Hints?
Why they use 10.0.0 unlike everyone else that is 192.168...
mborg10
Michael Borg
claremont meadows
I'm no network expert but our IT department told me IP starting with 192. Is what is used for private networks whereas others are public. I think this was done so we don't run out of Internet IPs
franky_888
Medowie
10.0.0.0 with a 255.0.0.0 subnet mask is still a private address (like 192.168.0.0 with a 255.255.0.0 subnet or any variant).
Just had a look at the doco myself and the only thing I can suggest is to ensure you've set the subnet mask of your computer correctly (255.255.255.0), and possibly change the ethernet cable to the NDB.
kenlmcse
Lightshowpro Developer
Gilbertsville, PA
I assume you are reading this: http://www.minleon.com.au/Minleon%20NDB%20Manual%20AUS%20-%20JAN%202004%2025th.pdf
Shut off all the other network adapters on your computer.
Set your computer's NIC to 10.0.0.10, the subnet mask needs to be 255.255.255.0 and the gateway needs to be 10.0.0.1
For the record, as long as you set the subnet mask to 255.255.255.0 you an use any IP address on the 10.0.0.x network BUT 10.0.0.100 because that address is being used.
After shutting down all other NIC's (wireless) on your computer, open a command prompt and type
ping 10.0.0.100
You should get a reply from the NDB controller. If you do not, take the gateway out of the IP4 settings on your NIC and try the ping again.
What I think is happening is your PC is trying to go to 10.0.0.100 through the wrong gateway. It is possible your cable modem and/or router has the 10.0.0.x network in it's routing path. This info gets forwarded to your computer so routing works. What you are doing is changing that routing to your NDB...
Once you can ping the device you are good to go. You might even be able to re-enable your other NIC's
The home network and the controller both need to be on 192.168 or 10.0 for them to talk to each other.
arw01
Eastern Washington
The real problem turned out to be the poor little beastie probably had a static jolt in shipping and needed the pic flashed.
once that was done, and the computers reset to put the nics at 10.0.0.5 I was able to bring up the config dialog.
I've reset to an ip address on my normal home network and am off to have it run some tests on lights.
I do wish it had a sexier test sequence than white, blah.
