Release 2023.15 Released
keithsw1111
Kellyville, NSW
2023.15 Oct 2, 2023
— enh (keith) Add Twinkly 3D Model import
— enh (keith) Add auto label of timing tracks
— enh (keith) Add option to lock effects on import
— enh (keith) Allow navigation of sequence settings metadata
— enh (keith) Add support for base show folders with inhereted controllers and models
— enh (keith) Add filter labels to shape effect
— enh (keith) In colour tooltips show closest colour name
— enh (keith) Add duplicate effect
— enh (keith) Add visual indicator if model/group contains effects on visible or invisible layers/submodels/strings/nodes
— enh (keith) Add visual hint in visualiser if pixels per port makes 40 FPS impossible
— enh (keith) Add option to fade piano keys on press
— enh (matte) Add optional timeline zooming to mouse
— enh (matte) Add keybindings for various toggling of render
— enh (djulien) Allow blank effect type to match all effects in select effects
— enh (djulien) Show models with effects when trying to make it master or when opening a sequence containing missing models
— enh (dkulp) Increase BBB max pixels to 1600
— enh (scott) Add genius pro controller
— enh (dartunder) Add option to keep size and location of models being replaced
— bug (keith) Fix buffer stagger disabled if effect dropped using key bindings
— bug (keith) Fix sketch effect check sequence not reporting missing images
— bug (dklup) Fix marque effect in release builds calculating incorrect buffer size
— bug (scott) Fix falcon v4 upload of sequences
— bug (dartunder) Fix current calcs in visualiser for multi-light nodes
— bug (scott) Fix ES Pixel Stick 3.2 upload
