darylc
404 darylc not found
- Dec 8, 2012
In this thread I will post what I know about Falcon firmware.  This is not a support thread.  If you think you have a problem with Falcon firmware I recommend you post on the falconchristmas.com forums.
Upgrade instructions https://pixelcontroller.com/firmware/How to Update Firmware.txt
v2.50
v2.50
- Available for F16v3, F48, F4v3
- Introduced Smart Receiver support
- Playback support - Standalone mode- Plays xlights FSEQ files stored on the micro SD card
- FSEQ file must be 20fps uncompressed
- Supports schedules and playlists
- Playback support - Remote mode- Same limitations as Standalone mode
- Lets your controller act as an FPP/xSchedule remote/slave
- Includes WIFI support (note you cannot send e1.31 packets to the controller over wifi)
 No longer available for download
- Fixed test mode bug. Would lock up network connection if test mode was selected when receiving E131/Artnet.
- Fixed controller from dropping off network when FPP (Falcon Player) or xSchedule (running as FPP master) is on same network.
- Fixed 2801 bug introduced with 2.50 firmware. Controller would crash if ws2801 was selected as pixel type.
- Does not support Smart Receivers being uploaded from xLights (https://falconchristmas.com/forum/index.php/topic,11117.msg99881.html#msg99881)
