needing a little bit of help :(
badger4543
S.E Melbourne
needing somone adavtek savy.. my display is looking nothing like it should look.
im using a rpi3B+ with fpp and 2 pixlite controllers.
i updated fpp and its hasnt been the same since. not to sure where i went wrong. i went back over all the stuff in the advatek assistant and in the advanced tab i tried manually punching in the pixel numbers, universes, and channels manually under the advanced tab when i would punch in a start channel it would change itself by one number after i entered my info..
im sure ive just missed a step somewhere..
badger4543
S.E Melbourne
a few more screen shots
MikeKrebs
Can xLights do the upload to your controllers? If so, I would do that.
Also your FPP config doesn't seem to match xLights. Did you push the config from xLights?
Goliath
Gracemere
I know nothing about xlights - I use a pixlite16LR and Vixen.
To my mind output1 should be universe 1/2, start channel 1, output2 universe 3/4 start channel 1 etc etc
Indigogyre
Journeyman Elf
Change your universe size to 510 and see if that helps. You don't exactly say what is wrong or what your are trying to fix. 510 channels is 170 pixels, 512 channels is 170.66 pixels. That could be causing an issue.
