CaptainMurdoch said:32x32 panels should work fine if they are 1/16 scan panels. I modified the code a long time ago to support these. I tested the code personally with a 64x64 P3 panel which was really 4x 32x32 panels put together in one frame.
In the FPP UI, just select 32x32 as the panel size and you should be OK.
deblen said:Hi
If that is the case Bbayjohn, what would I require to do, as the panels are not much use then.
Any suggestions would be greatly appreciated.
Thanks Deblen
smartalec said:CaptainMurdoch said:32x32 panels should work fine if they are 1/16 scan panels. I modified the code a long time ago to support these. I tested the code personally with a 64x64 P3 panel which was really 4x 32x32 panels put together in one frame.
that would explain why the p6 32x32 1/8th scan panels dont work..
deblen said:Hi Captain, thanks for the feed back.
Alex, thanks also for the feed back, looks like the Captain has it in hand.
Once again thanks to the efforts of the ACL forum.
Deblen
