Answered 12V addressable led strip light
Wayne Smith
I recently obtained a 12v addressable led strip light WS2812B Waterproof and for the life of me cant get them working. I have tried two separate 12v power supplies and with the data in (green wire) connected to my raspberry pi 3 as well as arduino uno but yet nothing. I do get a quick flash of some light when Initially plugging into a power supply but that is it. Any suggestions would be helpful20171230_131808.jpg
You would need both the data and gnd wires connected to the pi and have the 2811 outputs enabled/configured on the Pi. The Pi pumps out 3.3V logic and the pixels use 5V so ideally you should have a level converter of some sort to bring up the logic level. Connecting a 2811 tester is great for testing.
http://www.hansonelectronics.com.au/product/pixel-tester-2811/
Below shows part of the 2811 config within FPP
http://www.hansonelectronics.com.au/wp-content/uploads/2016/05/PI28D-2801and2811.jpg
Goliath
Gracemere
Others will have to help with the Pi/Arduino bits. I am told that plugging/unplugging 2811 chips to a live power supply is likely to blow chips. Always make sure power is turned off when doing this.
This thread is marked as solved. An answer might not be needed anymore.
