12v power into pixlite 16
sheidow park
so i dont smoke this controller too... anyone have a straight forward answer on how to configure the pixlite 16 with 12v input power (ie jumper settings etc)
I have read the user guide, but seem to have left my smarts at the office this week...
i assume i just ignore the CLK sockets when i add the pigtails, as i am using WS2811 pixel strings, and rgb strips.
cheers
lizardking
IT IS STILL ALL BENS FAULT
Gold Coast
there is no jumper settings for 12v or 5 v there is a logic fuse so you can run 12v one side and 5v the other side and yes if running 2811 pixels just dont use the clock connection +ve data and -ve
sheidow park
ok so i just add the 12v into the controller on j2 power bank 1 for channels 1-8 (making sure i get the polarity right)
no touchy for jumpers etc?
sheidow park
connected power to the pixlite 16, connected pigtail to output 1 (triple checked i have the right colour into each socket (GND, DATA and 12v+)
tested each pixel string. one has the first 15 not working (that is the one i blew up the cheapy controller on)
second string all light up white.
read in manual that once the controller is on, i can press "factory ip" for 3 seconds, then it will cycle through each colour... did that and they all stay white.
what could i be doing wrong?
gerry
Surrey Hills,Melbourne
What firmware level are you at ? Check that u have the latest.
Have you configured the outputs ? Or at leat for the one output you are testing..
