2 core pigtails from Ray Wu - Is there a better alternative?
Discussion in 'Computers, Cabling & Other Miscellaneous Hardware' started by cdjazman, Feb 20, 2017.
  1. cdjazman
    cdjazman Full Time Elf
    Apr 24, 2012
    317
    84
    This year I will be running power via 4mm2 cable consisting of multiple lengths.
    My question relates to using the 2 core pigtails that are thinner gauge wire from the top of the pic you see and then attaching that to the 4mm2 cable back to a 2 core pigtail.
    Would a short length of smaller gauge wire affect the voltage loss or would I be better connecting the 4mm2 without the pigtail.
    I am looking at having something set up that would be similar to controller boxes with pigtails hanging out but don't want to lose power.
    Is there any other options other than standard Ray Wu style pigtails? Any other products people have used?
  2. Heath-LightsOnTapley
    Heath-LightsOnTapley Senior Elf Generous Elf
    Aug 23, 2015
    608
    73
    sheidow park
    if 'weatherproofness' is not an issue, then i would do a direct connect.
    i have seen other people use automotive electrical connectors (scavenged from scrap yard cars) The Grinch used them on his mega tree enclosure.
  3. OP
    OP
    cdjazman
    Apr 24, 2012
    317
    84
    No 'weatherproofness' is not an issue as it will be mounted on the wall in the garage. Will check out the automotive connectors
  4. Heath-LightsOnTapley
    Aug 23, 2015
    608
    73
    sheidow park
    this is the thread for more info on those connectors
    https://auschristmaslighting.com/forums/index.php/topic,8857.15.html
  5. OP
    OP
    cdjazman
    Apr 24, 2012
    317
    84
  6. lithgowlights
    lithgowlights Senior Elf Generous Elf
    May 6, 2010
    841
    89
    Lithgow, NSW
    Look up "Anderson Plugs" on ebay. Less than $1 each delivered, and I use it for all my high current injection runs. for 5/12/24V weatherproofing is not required as these are designed NOT to corrode.
  7. OP
    OP
    cdjazman
    Apr 24, 2012
    317
    84
    Thanks for the heads up.
    Are you using the 30A or 50A out of curiosity. They look like they have some size about them.
  8. lithgowlights
    May 6, 2010
    841
    89
    Lithgow, NSW
    I use 50's, and when I had a look again they are just over the $1 mark, sorry. My last order was mid last year and I got 20 for $18 delivered :)
  9. Heath-LightsOnTapley
    Aug 23, 2015
    608
    73
    sheidow park
    are they basically like giant molex connectors Lithgow?
    what sort of crimper do you need for those?
    cheers
  10. OP
    OP
    cdjazman
    Apr 24, 2012
    317
    84
    Wondering if there was a reason for using 50A vs 30A..... my power supplies are only 30A..just thinking for plug size for me...
  11. SmartAlecLights
    SmartAlecLights Im a SmartAlec what can i say! Community Project Designer
    May 4, 2010
    1,241
    41
    S.A.
  12. OP
    OP
    cdjazman
    Apr 24, 2012
    317
    84
    I am liking the solar connectors. There are several options for T and Y connectors and being ip67 could use them both ends......
