Release 2016.28 release. pgo importer. Progress window. drag effects to zero seconds
smeighan
4217 Greenfinch Dr CO 80126
2016.28 release
Keith has added a super Papagayo *.pgo importer. With this release we can delete the old PAPAGAYO tab from xLights. Now your complete singing faces can be done entirely in xLights.
Here is a video showing importing pgo files.release 2016.28 on Vimeo] release 2016.28 on Vimeo
Gil fixed the drag of timing marks to zero seconds. No longer will it jump back as you move the mouse.
Keith added a progress window. When you click save you now will know when the save is finished without having to look for "Updated in xx seconds" on bottom line.
Latest releases are found at [url]http://nutcracker123.com/nutcracker/releases/]http://nutcracker123.com/nutcracker/releases/] [url]http://nutcracker123.com/nutcracker/releases/[/url]
Issue Tracker is found here: [url]https://github.com/smeighan/xLights/issues]https://github.com/smeighan/xLights/issues] [url]https://github.com/smeighan/xLights/issues[/url]
2016.28 May 10, 2016
-- bug (gil) Better fix for effects dragging past zero. This fixes dragging a timing mark to zero seconds.
-- enh (keithsw) Add papagayo timing track import via Timing Track Import context menu
-- enh (keithsw) Add progress display during rendering all
