Release 2016.50 xLights released. New ability to run xlights in batch mode
smeighan
4217 Greenfinch Dr CO 80126
New Release 2016.50
One thing in this release I like is Dan Kulp's feature to launch xlights from a DOS prompt.
Many bug fixes and enhancements. Thanks Dan, Gil and Keith!
2016.50 Sep 27, 2016
-- enh (gil) Allow arrow key to be used to scroll in model list in Layout. Fixes #582.
-- enh (dkulp) Add -r command line switch to render and save the fseq file and then exit
-- enh (gil) Modify value curve icon so its clear when its not selected. Fixes #675.
-- bug (gil) Fix crash when pasting bad data. Fixes #693 and fixes #694.
-- bug (gil) Fix extra preview windows not holding their saved position.
-- bug (dkulp) Fix node names used for HLS imports truncating the last character
-- bug (keithsw) Fix animated GIF files which were not rendering correctly
-- enh (keithsw) Make import and export of effects remember the last type used under assumption user is likely to want to use it again next time
-- bug (keithsw) Fix contrast on oversized sub-buffer. Yellow on light grey
-- enh (keithsw) Add links to common web resources to the help menu
-- enh (keithsw) Add palette reversal and deletion
-- enh (keithsw) Add multilayer insertion
-- bug (keithsw) Make output and model descriptions XML safe
-- enh (keithsw) Make garland lights on tree effect optional
-- bug (keithsw) Fix start channel check in check sequence calculating start channel incorrectly
-- enh (keithsw) Add custom model checks to check sequence
-- enh (keithsw) Add model checks to star and circles models to ensure all nodes correctly allocated
-- bug (keithsw) Fix some preset layer counting issues - string v3 presets from display as they cant be applied
-- enh (keithsw) Fix #340 - Add key model stats to model export
-- enh (keithsw) Add effect decriptions and effect export to get easy list of your effects in sequence and analysis of effect frequency.
-- enh (keithsw) Add check sequence check to highlight the network adapter we will output lights data to.
-- bug (keithsw) Increase maximum time offset for effects import from 10 seconds to 10 minutes
-- bug (keithsw) Fix model channel overlap checking in layout panel
