Release 2016.51 xLights released, PRODUCTION! Some major performance improvements
smeighan
4217 Greenfinch Dr CO 80126
Yeah! 2016.51 released, PRODUCTION
Major performance improvements.
Example:
"This is Halloween". Ver 50 300 secs, Ver 51 65 secs
"Thriller". Ver 50 541secs, ver 51 212 secs
Latest releases are found atwww.xlights.org] [url=http://www.xlights.org]www.xlights.org[/url]
Issue Tracker is found here:www.github.com/smeighan/xLights/issues] [url=http://www.github.com/smeighan/xLights/issues]www.github.com/smeighan/xLights/issues[/url]
2016.51 Nov 04, 2016
-- enh (chrisD) Update sequence checker to handle start channels in #IP:UNIVERSE:CHANNEL format
-- bug (keithsw) Performance fix for animated GIFs. Example: "This is Halloween" went from 300 second save to 65 seconds.
-- bug (dkulp) Fix mac<-->windows pictures effect filename mapping
-- bug (dkulp) Fix mapping onto nodes if nothing is mapped to the strand
-- bug (dkulp) Fix "Create Random Effects" taking forever to complete
-- enh (dkulp) Get the FPP Connect via FTP stuff working on the Mac, also allow named based FPP
-- bug (keithsw) Fix GIF scaleing not working.
-- bug (keithsw) Sequence Checker issue for Stars layers #721
-- bug (dkulp) Don't crash if polyline is set to singlechannel and start at right
-- bug (keithsw) Fix #612 ... missing effect settings scroll bars
-- enh (keithsw) Optimise logging in render loop ... means you cant turn on logging
-- bug (chrisD) Avoid crash if pasted data is empty
-- bug (chrisD) Fix github issue #709 "Fire effect height textbox entry"
-- enh (keithsw) fixed change the link button image and hover text in the Setup screen #342
-- bug (dkulp) Make sure picture effect is re-initted at start of effect
-- bug (dkulp) Fix crash on toggle strands when clicked on a strand instead of model
-- enh (gil) Add shutter support to DMX model.
-- enh (dkulp) Allow 180 trees to rotate and make sure they display as 180
-- enh (dkulp) Start all jobs that don't depend on anything above them first, then start the rest. 30% performance improvement
-- enh (dkulp) Make sure the list box is growable
-- bug (dkulp) Fix crash on render on some sequences
-- enh (Jennifer)added tool tips for countdowns
-- enh (Jennifer)New enhancements for countdown timer in text effect
-- bug (keithsw) Fix GIF handling of animated gifs where first frame is not full size ... ie it has an offset.
-- bug (keithsw) Fix video effect start time bug.
-- enh (keithsw) Allow VU Meter to use Papagayo layer 0 as a timing track
-- bug (chrisD) Fix rounding issue leading to unwanted gap between spirals
-- bug (gil) Fix model staying highlighted when removed from group. Fixes #707.
-- bug (gil) Prevent creation of unnecessary layer when promoting effects from only 1 strand.
-- bug (gil) Fix exception when opening Lyric Dialog. Fixes #710.
-- bug (keithsw) More animated GIF fixes ... all should work now
-- enh (keithsw) Add right click menu to controller list on setup tab including:
- Inserts controller(s) at a point in the list
- Bulk update IP address, channel count and description
- Bulk delete
- delete key and control-A to select all
- activate and deactivate are now available as right click menu items. Double click or ENTER key open the controller to edit it
- grey out inactive controllers
- open controller in your browser
-- enh (keithsw) Allow rubber band selection of models on layout tab without holding down shift key
-- bug (keithsw) keyboard nudging of multiple selected models now works
-- enh (keithsw) Add multi artnet universe adding
-- bug (keithsw) Fix seven segment states not sticking
-- enh (keithsw) Add FPP Connect which will upload universe configuration, fseq and media files.
-- enh (keithsw) Add start channel checks to check sequence
-- enh (keithsw) Fix #342 - add a tooltip to show dir/media dir link button to make it clearer what the button does in each state
smeighan
more details
More info on performance improvements.
11 Lilia sequences opened and saved on my desktop (Windows 7, i7 8x3.6g processor with 16g memory)
Column O is average of versions 46,47,48.
Other versions compared
BLUE: save times are < AVG*0.75
GREEN: Save times are AVG*0.75 to AVG*1.50
RED: Save times are >= AVG*1.50
Dan and Keith worked to get these improvements
smeighan
a user reported that his avast virus software reported the download as having a virus.
I suggest you scan our downloads with multiple virus engines. If we are infected, they all will all flag it.
https://www.metadefender.com/#!/results/file/ZTE2MTEwNkIxWmxBT1NHbmxnQmtHeFJ1SE1oeGc/regular/analysis
had 1 virus engine report a virus out of the 42 engines that scanned it
another web site
https://www.virustotal.com/en/file/8ee7d8b1432df95779b034d05ebff30e777e0b9de4c6460d8bcfb04455a34b7b/analysis/1478399594/
showed no infections with their 56 engines.
I believe that the user was getting a false positive.
