Hi folks,
After some discussions with the minister of finance we've decided to start implementing a controllable variety of lights. So with that in mind I've been designing up what I'd like to do. I'm hoping the very knowledgeable minds here can help guide me and fill in the blanks here and there. Here goes;
I've decided to scrap quite a lot of sections of lights that are currently made up of the Kmart etc string lights. These have been covering my vertical posts and the icicles have been dangling under the eaves. Instead I would like to create some arches (even though the area is squared off) to go between each vertical roof post. I'd like these to be of the iRGB LED type so I can program them. I've measured and the mounting arch would need to be 5.6m long so a 5m strip of iRGB should do I guess per arch (so x4).
The wife has requested some form of strip lighting around the edge of the lawn. I was also leaning towards iRGB LED strips, though they would probably have to be inside some form of clear tubing (I guess?). Measured distance would be 23m around the main lawn and 7m down the side of the driveway.
I've acquired some spiral planters from Bunnings 3x 1.5m and 2x 1.2m. I intended to cover these with iRGB LED strip also. Not sure if they would be best inside some form of clear tubing also? I haven't measured but am allowing 5m of strip per tree.
We've also picked up a bunch of ropelight motif things from Kmart and Bunnings. Several santas, some trees and some reindeer etc. All are 240v (/36vDC) powered so they're probably going to need to be dumb display items.
From what I understand, correct me if I'm wrong, each section of lights will be 1 channel of a controller; so a 16 channel controller can do 16 sections of lights. Each section can be lit or doing something at the same time as other sections or independently. Each LED within the channel is a single pixel and can be programmed independent of the whole channel. So LED 1 can be green, 2 red, 3 green etc.
The way I'm picturing it is laid out as such;
The spiral trees will each be a single channel (5), the front lawn will be another (1), the driveway edging another (1), the arches will be a single channel each (4). So I believe a 16 channel controller will work?
So from all of the above I think my shopping list will be something like;
iRGB LED Strip Lights (5m) x 9
iRGB LED Strip Lights (50m) x 1
What sort of cable do I use to connect the strip lights to the controller? CAT5?
16 Channel controller
Some form of program etc
Anyone know of a WiFi module to link the controller to a PC? Or alternatively something to run the program without needing to be connected to my main PC?
I can get hold of 12vDC power supplies no worries. So I figure since everything is localised around the front lawn a single 25A supply should work. Maximum cable run will be the 23m section.
Have I missed anything? Should I be reconsidering something? Am I biting off more than I can chew?
[font=verdana, arial, helvetica, sans-serif] [/font]
