Release 2017.23 xLights released
smeighan
4217 Greenfinch Dr CO 80126
Release 2017.23 of xLights
Developers keep cranking. Be sure to thank them!
2017.23 Aug 15, 2017
-- enh (dkulp) Add ability to specify starting location and direction for circle model
-- enh (keith) Add ability to manual edit effect timing - right click on an effect to access it
-- bug (keith) Fix model group panel no longer to able to repeatedly add/remove models using button
-- bug (keith) Fix scheduler does not properly restore from an interrupted schedule
-- bug (keith) When adding timing tracks only add them to master + current view
-- bug (keith) Fix some drag and drop anomalies on display elements
-- bug (keith) Add some SDL logging to track down OSX audio not playing bug
-- enh (keith) Fine tune AC UI ... try to make it more intuitive
-- bug (keith) Fix handling of expansion boards on the falcon
-- enh (keith) Allow AC sequencing on nodes
-- enh (keith) Some check sequence additions
-- bug (keith) Fix model rename breaks submodels
djgra79
Cranbourne West
Well of course it is because I just d/l .22 last night!!
Thanks all for your efforts.
marmalade
cats & pixels
newcastle
thanks, seems a bit more stable.It still crashes when scrolling fast through the effects (in effects settings) using the mouse wheel. Effect settings just goes blank and locks up.
Gilrock
Tucson, AZ
Do you mean scrolling the effects listed in the combobox? Hmm...never tried that I always just drag and drop effects. I would vote that we not allow effect type to be changed there if it was up to me.
marmalade
cats & pixels
newcastle
yep scrolling through the effects once placed in the sequence. Probably not the best idea but i do it a lot to see if any of the effects as standard in the combo box give a result that might be useful (rather than dropping an effect one by one and hoping to see something). Only happens when scrolling the button so fast the effects don't have time to update.
Gilrock
Tucson, AZ
Yep every time you change the effect its spawning a new render thread and trying to kill of the old one.
