Release 2017.28 xLights released. many bug fixes
smeighan
4217 Greenfinch Dr CO 80126
2017.28 released. Many bug fixes. Try the wiring view (on LAYOUT tab, right click a model and select Wiring View)
2017.28 Sep 18, 2017
-- bug (dkulp) Fix crash on startup when ViesModelsPanel is not visible
-- bug (scottH) Fixed Divide by zero error if main window is re-sized too small. (#913)
-- enh (keith) Add ability to import LAS files ... actually this existed ... it just wasnt selectable
-- bug (keith) Add warning if i am importing a datalayer that is bigger than the number of xlights channels
-- enh (keith) Add a xSchedule file play list item which can write information about current song etc to a file
-- bug (dkulp) OSX - Popup menu in "WiringView" dialog is completely disabled
-- bug (keith) Fix crash when change setup and then switch to layout
-- bug (keith) Fix crash when FPP master xschedule step finishes
-- enh (keith) Add creation of a phoneme track from channel data
-- enh (keith) Add model locking
-- bug (keith) Force value curves to update to real values ... it wasnt doing this which may have masked some issues
-- enh (keith) Add row heading tooltips where the model names are too wide to display
-- enh (keith) Add ability to display wiring view from the front
-- enh (keith) Add wiring views for most inbuilt models
-- bug (keith) Validate serial controller number of channels
-- enh (keith) Add ability to extract Phonemes from imported single channel face data
-- bug (keith) Fix timing track labels dont save if added to a fixed timing track
-- bug (keith) Generated submodels leave gaps on large models - overlaps are better than gaps
-- bug (keith) Rename "Output #" column on setup tab to just "Number" to try to address some new user confusion
-- enh (keith) Add optional auto hide show of house preview when playing
-- enh (keith) Add Make master capability to display elements which can take any view and copy its definition to the master view
-- enh (keith) Tag start channels with leading *** where the number has not calculated correctly
-- bug (keith) Prevent duplicate model start calculation errors from displaying
-- enh (keith) Add time display to play controls toolbar on house preview
