Release 2017.44 xLights released
smeighan
4217 Greenfinch Dr CO 80126
2017.43 released
2017.43 Dec 18, 2017
-- bug (gil) Fix bars gradient option when not alpha blending. Fixes #1032.
-- bug (keith) Fix xschedule text on single string vertical matrices
-- bug (keith) Fix xmap node level mappings not loading from file correctly
-- enh (keith) Add option to turn model blending off by default in new sequences
-- enh (keith) Detect low proportion duplicate nodes in custom models indicating possible accidental duplication of nodes
-- enh (keith) Ctrl-S works on all tabs as a shortcut to the relevant save button
-- enh (keith) Warn users when they switch to a backup show folder. Also highlight in check sequence.
djgra79
Cranbourne West
Here's the actual changes for .44 :)
2017.44 Dec 19, 2017
— bug (dkulp) Fix keyboard handling of numbers
— enh (keith) Add visual clue that xSchedule is serving web requests
— bug (keith) Add handling of mixed audio rates on windows/linux
