Release 2017.5 released. Some of the larger bugs addressed in this release.
smeighan
4217 Greenfinch Dr CO 80126
2017.5 released. A couple of larger bugs fixed in this release.
2017.5 Feb 23, 2017
-- bug (dkulp) Fix Pinwheel effects created before June 2016
-- bug (dkulp) Re-allow use of hostnames instead of IP addresses for outputs
-- bug (dkulp) Fix nullptr crash if master view has models that don't exist
-- bug (keith) Fix incorrect Property value count in e131 packets
-- bug (keith) Fix not handling inactive controllers correctly
-- bug (keith) Fix handling of Not Connected serial outputs
-- bug (keith) Fix xSchedule not applying global brightness correctly
-- enh (keith) Add arduino code for physical button control of xSchedule - this is available from GitHub only ... it isnt installed.
-- enh (keith) Add a run process to the scheduler that does not interrupt current playlist
