Release 2018.26 xLights released
smeighan
4217 Greenfinch Dr CO 80126
2018.26 released
2 enhancements , 4 bug fixes
2018.26 August 10, 2018
-- enh (dkulp) Use parallel algorithms in Twinkle/Butterfly/Plasma/Warp/Meteors effects to speed them up
-- bug (keith) Fix variable subbuffers not calculating correctly
-- bug (keith) Fix yet more animated gif issues
-- bug (keith) Fix some effects are wrapping pixels (eg picture, pinwheel)
-- bug (keith) Add back start parameter to sine based curves because timeoffset was not quite equivalent
-- enh (kevinp) New save icons
drakky
it's affected buffers on morph and curtain by the look before I had to have oversized buffers due to not being the centered now full buffer does the same thing
actually it seems it's changed the buffers for everything itself to
top 100
left -13
right 113
bottom 0
