Release 2018.4 xLights released
smeighan
4217 Greenfinch Dr CO 80126
2018.4 released
2018.4 Jan 30, 2018
-- bug (Billy) Fixed xScheduleWeb to display proper version number
-- bug (dkulp) Fix convert to effects not recognizing down ramps that hit the last frame
-- bug (dkulp) Fix problems with LOR v4 lcb only outputting 100% effect values
-- bug (dkulp) Convert To Effects only working for first node in model
-- bug (dkulp) CandyCane tops are chopped off in Model preview
-- bug (dkulp) CheckSequence erroneously flags 172.16 networks as broadcast. Fixes #1084
-- bug (dkulp) Fix problem with individual start channels on strings cannot self reference
-- enh (craig) Randomize only effect settings with a lock available.
-- bug (keith) Fix the arches model when start is set to the blue square
-- enh (keith) Force xtimging import to round down timing mark times if they occur between frames
-- enh (keith) Add the ability to include multiple timings in a single xTiming file
-- enh (keith) Add event triggers to scheduler which trigger command execution. Triggers available:
- On a channel value in the running sequence
- On a channel in a received E131 packet
- On a channel in a received ArtNet packet
- On a channel in a received DMX packet from a serial connection
- On a channel in a received OpenDMX packet from a serial connection - this looks like it will be less reliable than DMXModel
- On a OSC message
- On a FPP event
-- enh (keith) Add ability to send a FPP Event in a playlist step
-- enh (keith) Add ability to send to a serial device in a playlist step
-- enh (keith) Rework FPP/OSC remote so it works correctly with new event model and add ARTNet timecode support
-- enh (keith) Add magic fixes for overlapping channels and illegal start channels
