Release 2018.8 xLights released
smeighan
4217 Greenfinch Dr CO 80126
2018.8 released
This release sees a tech stack uplift. We are using latest CodeBlocks, Wxwidgets and Mingw compiler. We so these uplifts like every two years. There may be some things to work around. If you are a Windows 10 user you may need to run xlights in windows compatability mode. Your testing of the latest release helps Daniel Kulp, Gil Jones and Keith Westley to find the issues and fix them. Think of al of you as our beta testers for 2018.8. If you want, just wait a few weeks for any early issues to be resolved. I have tried 2018.8 and do not see any big issues.
2018.8 Mar 16, 2018
-- bug (dkulp) "Black" static text labels on Windows
-- enh (dkulp) Initial support for HiDPI displays on Windows
-- enh (gil) Improve phoneme placement when breaking down words.
-- enh (keith) Add a canvas blend mode and a transparent option to the off effect which will often be used together
-- bug (keith) Fix FPP event not being recognised by FPP
-- enh (keith) Add the option to loop event playlists when you start them
-- bug (keith) Stop all doesnt stop event playlists
-- bug (keith) Log illegal key bindings
  • Like
Reactions: AAH
