LawrenceDriveLights
- Jan 16, 2018
Just thought I would start a quick thread of what I am looking at doing for Halloween.
Now this is my first year with the whole sequenced light thing, so I am looking at using Halloween as a bit of a test run so to speak.
I am looking at using some of my props which are nice and easy to set up including
House Outline
Spiral Trees (with stars removed)
Arches & Sticks
2 x Wall Trees (42 node x 12 Strand) pixel matrix in the shape of a flat tree. I am using these to for some basic singing faces.
and some flood lights.
As well as P10 Tune To Sign
Here is a pic of my layout
View: https://www.dropbox.com/s/xdt2b37s3v9w6mg/2018%20Halloween%20Layout%20Pic.jpg?dl=0
I defined the node ranges for the singing faces in Xlights as I wanted the simple type faces for the Wall tree matrices.
View: https://www.dropbox.com/s/8h7181ki1lo9mo9/2018%20Halloween%20Face%20Definition%20Example%20Pic.jpg?dl=0
Then I was after a way to add some Halloween spookiness, in particular I was looking for a way to utilise the Ray Wu stars attached to the top of my sticks (here is how they look
View: https://www.dropbox.com/s/bm3id6nbs04the8/Photo%2029-9-18%2C%2010%2005%2027%20am.jpg?dl=0
I was looking for some cheap Jack o lantern type pumpkins to fit over the stars and found some Pumpkin Masks on Ebay.
View: https://www.dropbox.com/s/dwtu5qawmzovfk8/Photo%2029-9-18%2C%2010%2004%2052%20am.jpg?dl=0
So I made some quick coro supports which fit over the stars
View: https://www.dropbox.com/s/ekyx15f3moh4smg/Photo%2030-9-18%2C%209%2026%2029%20am.jpg?dl=0
Here is the masks fitted over the ray Wu stars
View: https://www.dropbox.com/s/2k2wnztuawv40xj/Photo%2030-9-18%2C%2010%2037%2025%20am.jpg?dl=0
I also cut out the mouths and eye sections a little more for the light to shine thru
They come up ok, and should look good at night
https://www.dropbox.com/s/dff0lhh67uj6l9u/Photo 3-10-18, 8 56 30 pm.jpg?dl=0
I don't have any animated props for our Halloween display, will just add some static props to give a bit of a Halloween theme.
Here is a quick screen shot from one of my Halloween sequences
https://www.dropbox.com/s/f6j64ktdtp0ho7a/2018 Halloween Sample Pic.jpg?dl=0
House Outline
Arches & Sticks
