Release 2019.18 Released
keithsw1111
Kellyville, NSW
2019.18 March 25, 2019
— enh (dkulp) DDP outputs can record the controller type (hat/cape) and upload menu item only shows it
— enh (dkulp) “Discover” button on setup tab to discover and automatically add/configure FPP instances
— enh (dkulp/keith) Add “Visualise” option for DDP/FPP controllers to see layout of models on controller
(work in progress)
— bug (dkulp) Fix problem with FPP connect not finding models if using hostname instead of ip address
— enh (dkulp) FPP Connect can update the start channel of matrices for LED panel capes
— enh (dkulp) FPP Connect can detect LED Panel capes, display the matrix size
— enh (dkulp/keith) Ability to use “Controller description” for starting channel (DDP only right now)
— enh (dkulp) xShcedule as FPP remote now works with Multicast protocol (maybe Linux/OSX only)
— enh (dkulp) xShcedule as FPP remote now responds to FPP Ping’s/Discovery
— enh (dkulp) Much faster FPP Connect discovery
— enh (keith) Add a LOR S5 LOREDIT file import. This is a highly speculative implementation at this time
Unless those who want this function lean in and help get it right it will likely never be
quite right.
— enh (keith) Use a dropdown for selection of Force IP address
— bug (keith) Fix slow render when using render cache
