Release 2019.36 Released
keithsw1111
Kellyville, NSW
2019.36 July 27, 2019
— enh (keith) Enhance text display in xSchedule
— enh (keith) Force valid show folder on xSchedule start
— enh (keith) Enhance xSchedule ping to show failure count and only count 3 consecutive fails as an actual fail
— enh (keith) Expand pixture effect frame rate adjustment upper limit to 20
— enh (keith) Default saving xmap to same name as it was loaded from
— enh (scott) Added Layer Blending Help Button
— enh (scott) Added Import/Export Model to Circle Model
— enh (scott) Added Toggle Effects Assistant Button to the Window Management Toolbar
— bug (scott) Fixed buffer transform for “Overlay – Center” and “Overlay – Scaled”
— bug (scott) Fixed “Blank” Star Model Import Bug
— bug (keith) Fixed three point models dont save their RotateX setting
— bug (keith) Fixed invalid OBJ crashes xLights
— bug (keith) Fix SMS Daemon settings dont apply immediately
— bug (keith) Fix SMS Daemon messages containing commas cause issues
— bug (keith) Fix shader panel does not show scroll bars
— bug (keith) Fix locked models resize when string properties change
— bug (keith) Fix model groups dont highlight correctly when changed
— bug (keith) Fix erroneous check sequence error for single channel matrices
— bug (keith) Fix value curve should not allow 0.0 or 1.0 point to be deleted
— bug (keith) Fix check sequence reports invalid error when text effect is drawing text from a lyric track
— bug (keith) Fix crash importing uncompressed music xml file
— bug (keith) Fix xSchedule white on white problem in dark mode for playlists list
— bug (keith) Fix Twilio download of SMS messages
— bug (keith) Fix deleting models when one has an effect on it
— bug (pete) Fix crash if render state is dumped while not rendering
— bug (dkulp) Fix OSX version does not show readme from help menu
— bug (dkulp) More OpenGL work
