Release 2020.49 Released
keithsw1111
Kellyville, NSW
2020.49 November 24 2020
— enh (scott) Added Import Model Blend Mode to xLights Sequence Import
— enh (keith) Allow remote falcon to only work while some playlists are playing
— enh (keith) Add to port tooltip in visualiser an estimate of the current draw on the port
— enh (keith) Add a brightness blend mode to xSchedule blend modes
— enh (keith) Add a way to renumber a DMX channel of a prop in the visualiser and then cascade to the rest of the models
— enh (keith) Add to visualiser colour bars to left of ports showing banks and smart remote groups
— enh (keith) When controller port limits are broken on the falcon show the largest port in each bank to ease troubleshooting
— enh (dkulp) Extend FSEQ file definition to support larger numbers of compression blocks
— bug (scott) Fix Group Count for Falcon Upload
— bug (keith) Allow xlights import to import from sequences that only contain timing tracks
— bug (keith) Fix an issue with music fade value curve which can create insane render times
— bug (keith) Fix unused smart remote throws off falcon upload setting of bank sizes
— bug (keith) Fix cant change height of 3 point models in model properties
— bug (keith) Fix unnecessary reboot of falcon on upload
— bug (keith) Fix double click on model category in model download seems to hang mouse pointer
— bug (keith) Fix window frame model sometimes loses a corner node
— bug (keith) Fix ZCPP does not default to auto layout when discovered
— bug (keith) Fix circle model wired from the inside
— bug (keith) When start of model is chosen default the channel offset to 1 as this is the most common choice
