Release 2020.56 Released
keithsw1111
Kellyville, NSW
2020.56 December 20 2020
— enh (keith) Add xScanner – this is like an IP Scanner but with xLights/xSchedule/FPP awareness and thus helps to
identify your network setup and spot issues. If you are joining the xLights zoom room with ‘network issues’
I would recomend you run this first and be ready to show the results
— enh (keith) Add a display elements sort option by controller/port
— bug (keith) On import of models containing groups when you chose to merge into existing groups it didnt really add the
submodels correctly
— bug (keith) Fix F4/F5 pull push of custom model nodes not working
— bug (keith) Fix crash due to long serial port name on windows
