Release 2021.04 Released
keithsw1111
Kellyville, NSW
2022.04 February 5, 2022
— enh (dkulp) MacOS: Move to FFMPEG 5 for accelerated ProRes video decoding on M1 Pro/Max
— enh (dkulp) MacOS: Update 3D Mouse support to manipulate individual control points
— enh (dkulp) MacOS: Enhanced iCloud support to make sure files are fully downloaded when needed
— enh (dkulp) Change export model videos to mp4 (from avi) to fix issues trying to import into various apps (like FinalCut)
— enh (keith) Add FX to single strand effect. This is a port of WS2812FX/FastLED as modified by WLED into xLights.
— enh (keith) Add keybindings for model data, faces, states and submodels
— enh (keith) VUMeter: Use sensitivity setting in VU Meter Timing Event Colour to control the transparency of the colour when no timing mark is actually present
— enh (scott) Change xlDo controller and model commands to use JSON list type. Added more lua type wrappers to methods
— enh (keith) Add ability to change temporarily multiple times before restoring to permanent
— enh (keith) Warn user if they change show folder to a non-empty folder that does not contain networks or rgbeffects
— bug (MikeSoukup) Include middle pixel for Single Strand / From Middle effect with odd number of nodes
— bug (keith) Fix falcon WAV file header validation
— bug (keith) Prevent negative drops on icicles
— bug (keith) F1 on layout tab can cause a never ending loop
— bug (dkulp) Fix undo of view object movements
— bug (dkulp) Fix video preview on Windows
— bug (keith) VUMeter: Level colour shows white before it is first triggered
— bug (keith) Crash loading submodel which references nodes that are out of range in the model
— bug (dkulp) Fix arch/single line/candycane rotation around center
— bug (gil) Fix issue with Per Model Default Deep not creating large enough buffer
