Release 2021.12 Released
keithsw1111
Kellyville, NSW
2021.12 April 12 2021
— bug (scott) Fix superstring model multistring channel count
— bug (scott) Fix key bindings that use CTRL on Windows
— bug (dkulp) Fix several instances of crashes when manipulating models on Layout panel while rendering (aborts rendering)
— enh (dkulp) OSX – Key Binding editor dialog should use the OSX key names and icons
— bug (dkulp) Fix crash in path editor/Value Curves. Occurs most often with lots of points. Fixes #2587
— enh (Old-Salt) Add bunch more shaders, restore some missing shader images
— bug (keith) Fix VUMeter does not work correctly with 40fps sequences
— enh (keith) Add the IMG_SIZE shader function
