Release 2021.23 Released
keithsw1111
Kellyville, NSW
2021.23 July 24, 2021
— enh (scott) Enable Inputs on FPP 5.0 when starting output to lights
— enh (scott) Added multisync text to mode column in FPP Connect
— enh (keith) Optionally include model description in visualiser CSV export for those that have hookup instructions
in the model description field
— enh (keith) Prompt for confirmation before deleting controllers
— enh (keith) All column reordering of the model list on layout tab and persist it
— enh (keith) Detect when user is opening sequence with many mismatched models and give them a quick way to exit and
try importing instead.
— enh (keith) Add quick show/hide timing tracks in master view (this will not work in other views)
— enh (keith) Show model amps in visualiser
— enh (keith) If using e131/artnet always show model universe/start channel in model tool tip
— bug (scott) Skip duplicate timing marks in vamp imports
— bug (keith) Fix custom models with > 65535 nodes dont work
— bug (keith) Fix Cube model Horizontal and Vertical Per Strand model group buffer broken.
— bug (keith) Fix visualiser move model between ports not working
— bug (keith) Fix the fix for OSX link button preference saving
— bug (keith) Fix polyline 2 point model shows in model preview as diagonal line unless perfectly level/vertical
— bug (dklup) Fix render progress bar not appearing
— bug (dkulp) Retain the output interface that FPP is using if the user has set it
