Release 2021.36 - 2021.37 Released
keithsw1111
Kellyville, NSW
2021.36 November 9, 2021 (manually imported from README.txt)
— enh (dkulp) Fix crashing on OSX 10.12
— enh (dkulp) Warn on OSX 10.12 and 10.13 that support will be dropped soon, update to 10.14 will be necessary soon
— enh (dkulp) More work moving to Metal on macOS
— enh (dkulp) Esc to cancel drag/paste in Pictures assist
— enh (dkulp) Add Butterfly types 2-5 to "Experimental GPU Rendering" option
— enh (scott) Added Flip Horizontal and Flip Vertical to Layout Tab
— enh (scott) Variou smart receiver type checks
— enh (scott) Increased ESPixelStick v4 ESP32 Max Universe size to 12
— enh (keith) Add the ability to use a state as a face outline when using node ranges
— enh (keith) Add entec controller properties (no upload yet)
— bug (keith) Prevent discovery duplicating controller names.
— bug (keith) Fix sequence being marked as dirty when it isnt really.
— bug (keith) Replace model with this model does not prompt if the model is on No Controller (#2910)
— bug (scott) Don't override ESPixelStick controller parameters if not set in xLights
— bug (scott) Workaround for ESP32 lockup issues
— bug (scott) Default HinksPix 16 Port AC to 0 start pixels
— bug (dkulp) Fix dragging of selection in Pictures assist window
— bug (dkulp) More of a workaround - CTRL-C/V copy/paste in Pictures assist. Cmd-C/V still not working.
— bug (Shelby) Upgraded libcurl on Monterey defaults to chunked transfers which breaks uploads to ESPixelStick
keithsw1111
Kellyville, NSW
2021.37 November 12, 2021
— enh (dkulp) Add LED Panel output to Pi based FPP controller types
— bug (dkulp) Fix Life effect not rendering past first frame
— bug (keith) Insert Prior seems to max out at 50 but the number box allows larger numbers
— bug (keith) Fix crash with Pictures Effect Assist panel
— bug (keith) Fix media upload repeats to FV4 whwn it shouldnt
