Release 2022.06 Released
keithsw1111
Kellyville, NSW
2022.06 March 6, 2022
— enh (gil) Add auto repeat option to Morph. Automatically scales the repeat to model size.
— enh (keith) Add a low definition rendering mode to matrices
— enh (keith) Enhance we way transition times are set
— enh (keith) Add exportModelWithRender to API
— enh (keith) Add radial colour curves to the on effect
— enh (keith) Add greater precision to wave effect speed
— enh (keith) Allow disabling of render at the element level
— enh (keith) Add word flip movement to the text effect
— enh (keith) Add a reverse lookup from rendered data to source effects
— enh (cpinkham) Add z coordinate to the FPP virtual display map
— enh (dkulp) Adjust xLights calls to FPP to use tweaked API
— bug (keith) Fix presets using per model buffers dont preview correctly
— bug (keith) Fix model default type causes face definition to not save correctly
— bug (keith) Fix polyline reports incorrect real world dimensions
— bug (keith) Fix missing gridlines in morph effect assist
— bug (keith) Fix blended circles have an incorrect coloured halo
— bug (keith) Fix when effect dragged from palette drop location not shown in the waveform
— bug (keith) Dont add inactive models to a model group … this will stop them displaying but may create other issues
— bug (dkulp) Provide a workaround to spaces in material file names
— bug (scott) Fix issues with ordered node selection for submodels
