Release 2022.07 Released
keithsw1111
Kellyville, NSW
2022.07 March 28, 2022
— enh (gil) Add Jaw Orientation property for the DMXSkull model
— enh (gil) DMXSkull model changed so color error checking is only done when color channels are active
— enh (scott) Added Effect Settings Search Panel.
— enh (scott) Added Text Replace to Text Effect ${TITLE},${ARTIST},${ALBUM},${FILENAME}.
— enh (scott) Added Support to Import S5 .lorprev Preview Files.
— enh (scott) Added WLED Dig-Uno ESP32 Variant with correct pins.
— enh (scott) Added WLED Warning For Firmware v0.13 & v0.13.1 not working with Controller Upload, use v0.13.2 or v0.13b5.
— enh (scott) Added xLightsAutomations APIs to get and set Effect Settings.
— enh (scott) Added Lua commands for TableToJSON and Table Logging.
— enh (dkulp) Add a timer for video export
— enh (dkulp) Move 3D checkbox so it does not get lost when screen sizes are changed
— enh (keith) Add the minleon 4 port NDB controller
— enh (keith) Use number aware sorting in test dialog for models and submodels
— enh (keith) Add the ability to split the current effect
— bug (scott) Fixed wrong HSV value with On Effect added in 2022.6
— bug (keith) Fix state dialog shows colours even when force colours is not set
— bug (keith) Fix wave effect frozen at frame rates over 20ms
— bug (keith) Fix visualiser does not show port number for models on other controllers
— bug (keith) Fix jerky model video playback due to frame count interpretation error
— bug (keith) Restore AVI export on windows for model video so lossless compression works
— bug (keith) Fix issues with make all model start channels valid not working
— bug (keith) Fix xSchedule POST requests issued as GET requests … this will need to be re-setup.
— bug (keith) Fix uploading to minleon controllers
— bug (keith) Fix sequence number bug in KiNet protocol
— bug (keith) Fix crash in text effect in animation sequences
— bug (keith) Fix save sequence does not update MRU
