Release 2025.05 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2025.05 April 14, 2025
– enh (cybercop23) Add optional status led for each controller on Controllers tab (enabled in settings)
– enh (derwin12) Add popup menu option to close gaps between effects
– enh (derwin12) Add “Alternate Nodes” option to Sphere model
– enh (derwin12) Adjust Save and Save As tool tips to reflect if Render on Save is enabled
– enh (derwin12) Allow Seconds + Millisecond for timeline instead of m:s:ms
– enh (scott) Sub Model Dialog – add ability to pad the front/rear of rows to make them uniform
– enh (derwin12) Colorize X/Y/Z coordinates for BoxScreenLocation based models
– enh (keith) Render Progress dialog can save position/size
– enh (derwin12) Handle IPV6 proxy addresses if hostname resolves only to IPV6
– enh (dkulp) MacOS – point Mac VAMP users to new 2.0 plugin pack
– enh (cybercop23) Show stated of effect render status in popup menu
– enh (derwin12) Add number of effects to left side of Import Mapping
– enh (cybercop23) Add Export Faces & States to other Models
– enh (derwin12) Add leftright text effect option
– enh (keith) Mark sm16804 as a supported pixel type
– bug (derwin12) Only enable media adjustment buttons if media is actually found
– bug (derwin12) Fix problems rendering some multi-path SVG’s
– bug (derwin12) Tweak preference panes for smaller screens
– bug (cybercop23) Fix populating properly list when searching for model
– bug (cybercop23) Fix some problems with fade in/out of audio with the prepare audio functions
– bug (cybercop23) Fix settings not properly reflected after bulk edit
– bug (MartinMueller) Fix some issues with ESPixelStick uploads
– bug (derwin12) Fix some crashes with the Video effect
– bug (derwin12) Fix a crash with Pinwheel effect
– bug (derwin12) Fix F48v3 discovery
– bug (derwin12) Account for alt nodes when display node layout
– bug (dkulp) Hopefully fix crash on Mac when using keys to navigate/select choice options on property grids
– bug (derwin12) Abort render if effects moved to prevent crashes
– bug (dkulp) Fix crash with effects on empty groups, don’t add render jobs for models/groups with no nodes
– bug (dkulp) Make sure only “active” models are used to compute nodes of groups with named cameras
– bug (dkulp) Catch Crashing Emoji Effect on single line buffer styles
Status
