Release 2026.02 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2026.02 February 10, 2026
-change(scott) Move from Ubuntu 22 to Ubuntu 24 for Linux
-enh (dkulp) Update to latest wxWidgets (fixes some issues with File selection on OSX, some Windows dark mode fixes, etc…)
-enh (MrPierreB) Allow chosing a larger size for the color selection buttons on the Color panel
-enh (derwin12) Highlight perfectly vertical single lines similar to how horizontal is shown
-enh (dkulp) Allow using AppleIntelligence/ImagePlayground on M# Macs to generate images
-enh (derwin12) Allow using Gemini to generate images
-enh (dkulp) If both ChatGPT and AppleIntelligence are enabled, allow selecting which one to use for Color Pallete generation
-enh (derwin12) Add check sequence warning for reveresed single lines
-enh (derwin12) Optional ring bell if error during batch render
-enh (derwin12) Disable sequence duration change if media is selected
-enh (keith) Updates for new pixel protocols for Minleon controllers
-enh (scott) WLED Add Full xLights Control that uses xLights GPIO pins to allow Port Skipping and sets brightness factor from default brightness
-enh (derwin12) Provide new source for QM Vamp for Windows
-bug (derwin12) RGB Image models in layout may be be invisible
-bug (derwin12) Fix or workaround several potential crashes
-bug (derwin12) Fix potential crash in text effect if using external file for text
-bug (derwin12) Fix FSEQ info being dumped on slight channel mismatch
-bug (derwin12) Add warning to clear render cache if FPS is modified
-bug (gil) MH Effect: If all commands have the same position reselect the fixtures from the commands
-bug (gil) Update so new MH head effects are always have no commands. New MH’s select all fixtures. Reselecting existing MH effect unchecks fixtures
Status
