At the bottom of this post I will have the attached STL files to enable people with 3D FDM style printers to print their own copies.
Designs are for personal, non commercial use only. Links may be placed on other sites back to this thread.
The mounting plate is designed with mounting holes on the outside that line up with the captive nuts on the short panel brackets
I use Simplify3D as my slicer so the following may need to be varied based on your slicer, machine and filament.
I have printed these successfully in ABS using the basic settings of
Layer height: 0.2mm
Print Speed: 50mm/sec to 70mm/sec
Outline underspeed 90%
Infill: 10%
Otherwise use all your preferred slicer settings that give you accurately sized prints.[/SIZE][/FONT]
Now the bbb mounting holes are slightly undersize for a M3 threaded bolt to ensure a good fit for the M3. I just use a M3x6mm one and thread the holes first using a cordless screwdriver/drill
Two attachments
First has 3mm mount holes, fine if your printer prints holes fractional small
the seconded has mount holes 2.8mm
Layer height: 0.2mm
Infill: 10%
Two attachments
