A new home (For 10 months) Storage for your investment
Discussion in 'Tips and Tricks' started by Derf, Jan 24, 2018.
Tags:
  1. Derf
    Derf Full Time Elf Generous Elf
    Dec 1, 2016
    146
    78
    Narellan, NSW
    Hi everyone,
    I just thought I would share my previous weekends work to find a more permanent less disturbed home for my lighting elements.
    I purchased the cheapest shed from bunnings that would accommodate all my display elements with more room for the years of creating i'm prepared to do.
    https://www.bunnings.com.au/pinnacle-2-3-x-2-3-x-2-4m-garden-shed-zinc_p3312677
    I've anchored it to the pre-existing concrete slab so it doesn't blow away and the end result was quite a sturdy shed.
    [​IMG]
    [​IMG]
    I'm currently building shelves for the smaller items and using roof hooks to store the arches as they disassemble quite easily. (This might be the long weekends project) (Australia Day).
    Currently I store the following:
    • Roll's of WS2811 Strip
    • Conduit
    • new and used cables
    • amplifier
    • speakers
    • controller boards and enclosures
    • extension cables
    Essentially I try keep everything relating to the show in this shed and nothing else (Expect for the blower as there is no room for it in the garage and back shed). so I can pull everything out and it is ready to go.
    Some things that I need to improve:
    1. As it is a zinc coated shed it absorbs the heat quite a lot making it around 60-80*c inside. So I plan on cutting in a roof exhaust or an indoor to outdoor bathroom fan vent on the rear wall.
    2. I would like to run underground power to the shed to either run the fan on a thermostat or just to have a GPO around that back end of the corner without having to run a 20-30m extension cord!
    Any suggestions / feedback is appreciated. I would also like to see how you guy's store your items for ideas on how to maximise storage.
    Derf | Jack
  2. OzAz
    OzAz Senior Elf Generous Elf
    Dec 29, 2015
    614
    204
    Newcastle
    watching with interest
    have you considered insulating the shed? would probably need to use "closed cell spray foam" not sure how much this would cost though
  3. Ralphyf1
    Ralphyf1 Apprentice Elf
    Jan 11, 2016
    89
    29
    2 Brook Court , Kidman Park
    Hi Derf,
    great idea.
    From personnel experience using a small shed, I had trouble with humidity and condensation inside causing all my garden tools to rust very quickly. What I ended up doing for my garden shed was buying a small whirlygig thingy and mounted it in the roof and cut a small panel out quite low down in one wall which I covered with fly-wire Seemed to give enough airflow to solve the problem for my garden stuff. But I am sure someone will have a better idea! cheers Ralphy
    OzAz likes this.
  4. Ellis
    Ellis Naughty Elf
    Aug 21, 2017
    207
    150
    Gold Coast
  5. OP
    OP
    Derf
    Dec 1, 2016
    146
    78
    Narellan, NSW
    We have a product that I borrowed from work without asking called Foilboard
    https://www.bunnings.com.au/foilboard-2440-x-1200-x-20mm-ultra-20-insulation_p0810878
    I actually used this to insulate a fish shed for my grandfather but found an exhaust fan do the same thing really. As Ralphy also stated with moisture that having a vent would be a lot better in the long run so I think I will opt for that Idea.
    ~Derf
  6. Fing
    Fing Full Time Elf Generous Elf
    Dec 31, 2014
    398
    45
    Muswellbrook
    Gunna need a bigger shed......:D
    Goliath likes this.
  7. OzAz
    Dec 29, 2015
    614
    204
    Newcastle
    or do both :)
    lithgowlights likes this.
  8. lithgowlights
    lithgowlights Senior Elf
    May 6, 2010
    871
    110
    Lithgow, NSW
    I would Oz, yes
  9. Fing
    Dec 31, 2014
    398
    45
    Muswellbrook
    If you can get foilboard at the right price then it would be a good start and costs nothing to run, being a tin shed, the tin heats up and then radiant heat will impact your stuff in the shed, the foil board will stop that radiant heat as it's a barrier.
    I would space it off the tin with some battens, say 20mm, to improve its performance as it's not touching the shed and there will be no heat conduction.
    A ventilator will help with humidity, but it will only lower the air temp to that of the ambient outside air and does nothing to prevent radiant heat from the walls which is where the heat comes from.
    Fing
  10. Goliath
    Goliath Full Time Elf
    Dec 31, 2014
    114
    37
    Gracemere
    I have a similar pitched roof garden shed. The pitched roof isn't designed very well, and during storms, rain blows up under the ridgecap, and into the shed. Once had a half a bucket full of water sitting under the ridge. That was extreme though - it was after cyclone Marcia.
  11. OP
    OP
    Derf
    Dec 1, 2016
    146
    78
    Narellan, NSW
    Thanks for the heads up I think I might put some sikaflex or something similar in the ridge capping
    Thanks Derf
  12. fxxxrr
    fxxxrr New Elf
    Aug 31, 2014
    39
    1
    i have a 3m x 3m shed and for one reason or another the door never gets shut and in 12 years i have had no issues with humidity etc
    luckily the prevaing weather comes from opposite side of shed to my door lol, but even in some pretty serious rain very little if any actually gets in
    ive got everything stored in there, car parts camping gear mowers , garden stuff, boxes of clothes, old PC stuff, i did have boxes of books but the ants got into them
  13. David_AVD
    Jun 12, 2010
    3,978
    272
    That brings up a good point. Probably best to lay down some surface spray before loading all your gear in.
  14. Heath-LightsOnTapley
    Heath-LightsOnTapley Senior Elf
    Aug 23, 2015
    615
    76
    sheidow park
    install more gecko's
  15. David_AVD
    Jun 12, 2010
    3,978
    272
    Geckos make a mess in my shed. The ones we have around here are not native to Australia and are a pest.
